Reading an Audi Dipstick
Old 10-05-2013, 07:50 PM
Steppenaudi's Avatar
Default Reading an Audi Dipstick
I'd like to know if the dealership over-filled my engine oil. I've got a real dipstick for the check (the MMI shows full, but really no way to show over-full as far as I can tell).
Bare dipstick (top image below):
Dipstick from engine currently (vehicle on a level surface) (second image below):
Note that the oil level covers the "MAX" mark completely. Is this the way "full" should look, or is "full" supposed to be to the right of "MAX" at the bend in the dip stick?
When I changed oil at 1000 miles, I had the oil level to the right of "MAX" at the bend, and the MMI display read full.
Old 10-05-2013, 07:54 PM
gtwagon941's Avatar
Looks overfill to me. Let is sit overnight and check Again. If it's above the line again, you've got issues.
Old 10-05-2013, 08:36 PM
MP4.2+6.0's Avatar
Default Looks overfilled
Should be no higher than that upper slight bend of dipstick at most AFAIK. I've seen better marked dipsticks from Audi, but it's either that or only where those diamond pattern marks are stamped into it further toward the center of the offset bend area.
I have the regular 2.0T dipstick (assuming that is what you are using), so I'll stick it back into the Hybrid when it's back tomorrow night and report back. It still has the Euro factory fill, the display last read full, and none has been added.
I'm guessing that like me, you found that dipstick won't fit in there permanently and clear the top motor Hybrid trim cover.
Old 10-05-2013, 08:49 PM
Yep, and I bought it in part to leave it in all the time.
BTW, the vehicle had been sitting for at least two hours. The engine was cold.
I suspected from the dipstick reading that it was too full, but I wanted confirmation .
Old 10-06-2013, 07:01 AM
AudiWorld Expert
Reggie's Avatar
2nd that - No matter how good the dealership is mistakes happen and why I don't rely on the MMI either
Old 10-06-2013, 07:38 AM
I can confirm that my dipstick is the commonly accepted part for the 2.0 TFSI engine (PN#: 06J-115-611-E).
Can someone who does their own oil changes on this engine confirm what this dipstick reads with the engine nominally full if oil?
Old 10-06-2013, 09:44 AM
gtwagon941's Avatar
On this topic...just picked up our SQ5 and I'd like a physical dipstick...is that a possibility on the SQ5?
Old 10-06-2013, 10:13 AM
spijun's Avatar
I'm not 100% sure but I think you need S / N: 06E-115-611H
Your model has the same tube for oil dipstick S/N: 06E-115-630B as well as other models that use the S/N 06E-115-611H
http://www.europaparts.com/oil-dipstick-06e115611h.html
http://www.ecstuning.com/Search/06E115611H/ES280765/ or http://www.ecstuning.com/Search/06E115611H/ES2070647/
Old 10-06-2013, 10:39 AM
Bob Petruska's Avatar
Default Remember they suck your old oil out...
to do the oil change, and if they don't suck it "all" out and replace it with the specified new amount it will be over filled. I persoanlly don't think that you have any problem here with a slightly overfilled level. The crankshaft needs to hit the oil to make foam to cause any problems. Your oil level is way below the crankshaft at this point, the Audi engineers know that with this sucking out the old oil that potential for overfilling exists and they gave you a lot of room for error. My 2002 A4 required 6.7 quarts of oil, I always dumped in all 7 quarts, zero problems. You will be surprise how little oil is needed to be removed to bring it down to the "X" on the MAX mark. My factory fill was at the "X" of the MAX mark and is still there 1500 miles later so I hope I got a good 2.0T that doesn't consume oil.
Have you ever thought about how high the oil level gets towards the crankshaft in the sump when the vehicle goes up/down a very steep incline? So that tells you there is ample clearance from the oil level to the crankshaft.
If it really bothers you just go to the dealer and let him suck out a few oz/mL to give you what you want. It should take only a few minutes. For a DIY, all you need is a hollow rod/tubing of plastic and a turkey baster (1$ at dollar store) duck tape it on to the tubing and suck out the oil overfill quantity.
Old 10-06-2013, 12:36 PM
I'm a first-time Audi owner, so I no experience with how much engineering margin was provided in the oil level and crankshaft clearance. I would estimate from the dipstick that there's at least a half-quart too much oil in the engine. I could suck out oil until I hit the right level on the dipstick with a hand vacuum pump if necessary. I did this for an oil sample before the 5K service for a UOA.
However I'd like to know if the dipstick reading is valid based on an owner-performed oil/filter change with the specified oil volume in the engine. Since the vehicle didn't come with a dipstick, what I have may be over-estimating the fill level.
Quick Reply: Reading an Audi Dipstick
