Suggestion - 2014 Audi Q5 MPG
#21
got a 2013 2.0T a month ago, just filled up the 2nd time a couple days ago and got 350 miles to the tank, calculated at 20mpg, computer showed 22mpg. Dissapointing to say the least, seeing as how my 10 mile commute is 9 miles on the freeway. Gets worse mileage than my 97 12v a4.
How many miles on it? Was the PCV valve replaced? Engine oil level is constant?
With my 2.0T, I get about 21mpg in city driving including some slow speed (traffic) highway for a 6 miles commute here in Canada, in cold winter days (not too much snow). But I drive it easily and let the engine warm up a good 4-5 minutes before driving. Summer highway at 65mph was 30mpg. I don't use the Sport mode.
#22
- 2014 Q5 2.0T
- 65 -75 mph on I80 in "D" mode
- northeastern PA, 30 degrees F today
- winter blend gas
- before trip filled up with gas to auto shutoff, refilled same way at same pump after trip.
I normally only drive with the trans in "S" mode and I get about 18 mpg with 75% city/25% highway.
#23
28 mpg with 100 mile round trip today, which included climbing 2 long mountains.
- 2014 Q5 2.0T
- winter blend gas
- 2014 Q5 2.0T
- winter blend gas
#24
#25
As for the pcv, if it was not changed yet, it will be due sooner or later. I think Audi is offering extended warranty for this part.
#26
FWIW. The low-ish numbers for the 2.0T mpg has been my experience on the 2 occasions I've had a Q5 2.0T loaner. It just wasn't much better, if at all, on my daily drive than my 3.0T. I believe therein lies the key... Everyone's driving conditions and style vary so it's really tough to compare absolute numbers here in the forum.
I look at it this way, now that both 2.0 and 3.0T have the 8 speed, the efficiency aspects there are comparable. So, admittedly with some hand waving, if I was to drive both cars for maximum efficiency with no other goal, the 2.0T will be better. It just will, again, driven for best MPG. You aren't running under boost on either engine if driven properly for best MPG, so you are essentially comparing an NA 2.0 4 cyl vs. a 3.0 V6 plus the drag of its supercharger running in bypass. More parasitics and overhead on the V6 will translate to worse efficiency.
Now, if you drive both with the same daily-driver "performance" goal -- same accel rate from lights and such regardless of engine, you are going to be into boost much more on the 2.0T and in lower gears. The result, pretty poor 2.0T mpg because you require the same torque/power to get things moving regardless of engine.
I think that's key to the whole MPG discussion in general - the small, turbo engines have a more efficient range to dip into that the larger engines do not, so they are capable of better mpg. Much of the advantage goes away though if you don't change your driving style to take advantage of that capability.
#27
My old 1.8T Passat was fine for the most part until it got older and I had to work it more (but had the 5-speed Tip and so wasn't able to stay in low revs like the 8-speeds we now have can). My Odyssey I had to really work over to get it to move adequately which was stressful for both me and the engine. It got terrible mileage in general, though, never hitting the highway estimate even on long freeway cruising. My TDI has more than enough power so I never have to push it hard... though I can if I want to.
Definitely all about what's most appropriate for you, as we're all different. My wife drives pretty aggressively, too, scooting all over in her Golf TDI, but the way that she applies throttle she's able to get a little better efficiency than I can.
#28
Vapor pressure? Don't get all bent out of shape, winter blend is gasohol and the alcohol content has WAY LESS FUEL DENSITY than gasoline does. All you need to know is that it waters down the gas.
Tire size, inflation pressure, snow on the road, highway speed, use of cruise control or an erratic right lead foot, roof racks on to add drag, all these things matter as much if not more.
This news to you?
This news to you?
#29
I have been pleasantly surprised with my 2.0T this winter. I have been averaging better than 22 mpg (based on calcs, not trip computer) in my commute, which is about 2/3 hwy and 1/3 city. And I live in the frozen tundra (Wisconsin). However, I always fill up with premium that contains no ethanol.
#30
I'm getting an average of 19mpg (calculated) mixed which isn't bad. In Metro Vancouver it's basically city driving and semi-spirited. The best I got was 25 from Vancouver to Portland which was all highway. I find the 2.0T mpg a bit disappointing. Especially hearing what 3.0T and TDI drivers are getting. Maybe I should have ponied up and gotten the 3.0T or TDI. =(
