TDI engine temperature
#11
Points I was trying to make were that:
1. Engine oil isn't as effective at protecting the engine until it reaches proper operating temp.
2. Moisture and fuel don't evaporate from the oil very well until the oil has been at operating temp for some time. If this is happening on a regular basis, you might consider reducing your oil change interval.
#12
And diesels are notorious for lasting hundreds of thousands of kilometers. And gasoline dissolves the oil off cylinder walls. And I don't want my A6 TDI to last too long anyway because I want a new car every 3 or 4 years.
I don't understand the slow heating or the temperature dropping back--maybe a thermostat is opening prematurely or wide open at too low a temp. My TDI takes 6-7 minutes to reach normal temp and about 2 mins to be pumping warm air to the passengers. I think it's time for a trip to the dealer and don't accept that "it's normal."
#13
Let it idle on a cold day. See how long it takes to warm up to normal operating temperature, if it gets there at all. Diesels are extremely thermally efficient especially at idle. They don't give off much waste heat and the only real way to warm it up is to just drive it.
In the settings, there's one for an external heater. Our vehicles are fitted with a ceramic heater that turns on that can provide heat to passengers before the engine warms up. I find it gives heat quicker than my 2.0t ever did. I also find the diesel, once warm, stays warmer longer than the 2.0t
#14
My 2015 TDI warmup time is slightly longer than my Chevy Truck. However it is not that noticeable and temp stays at halfway. Something doesn't sound just right for it to fluctuate much. My gauge is steady after warmup. Use your seat warmers also.
#16
Can anyone confirm that at these temperatures their TDI definitely does not do this?
#18
I can confirm it, but my opinion means little. If your dealer is playing the IDK card (although swapping sensors was a worthy shot), you might want to ping some northern tier VW/Audi service departments. Short of that long shot, you're at the mercy of the corporate-Audi answer. If nothing else, at least you have it documented with Audi if something happens later...
#19
#20
My gauge is relatively steady after warm up. It is at the colder temperatures during the warm up that it fluctuates. Do you drive in an area that gets that cold? If so, does your gauge fluctuate during warm up?
D.boy23
A4 (B7 Platform) Discussion
12-05-2015 06:23 PM
dan-needabimma
01-20-2006 06:16 AM
AndrewsQuattros
01-05-2003 11:08 AM
