VCDS (VAG-COM): a couple of questions - AudiWorld Forums
Go Back   AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Q5/SQ5 Discussion
Log In
Q5/SQ5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
LinkBack Thread Tools Search this Thread
Old 08-11-2012, 03:07 PM   #1
ThunderDent's Avatar
Default VCDS (VAG-COM): a couple of questions
So far I've done quite a few little mods, which have all seemed to go pretty well.
So far I have:
*Enabled Gauge/Needle Sweep on start-up (really gives the Q a "sporty" feel)
*Set fog-lights to work with high-beams as well as low-beams (so nice)
*Set fog-lights to track corners when turning steering wheel (major difference, it is really nice driving a twisty-turning road now at night)
*Set the Drive "D" and Sport "S" mode to display gears (D1-D8, S1-S8).
*Removed seat belt chime on start-up (so much nicer to just hear the engine when you turn on the car instead of a bunch of stuff beeping at you. Silence is golden here)
*Set-up the Key FOB to open Windows/Sunroof from the remote. (I just set mine to do front windows and sunroof, but you can choose to add rear windows if you like out of the MMI. The sunroof option IS present in the MMI, and what it does is tilt the roof and open the cloth sun shield up a little less than 1/4 of the way).
*Disabling rear window wipe on reverse (a must have come winter time!)
I have also, through the Hidden MMI menu:
*Enabled the Interior Ambiance Lighting in the MMI menu.
*Attempted to change the MMI Splash Screen in the hidden menu with no luck, but other sites have covered this problem ad nauseam, so I'll go with those for explanation of the problem. Some say it shows up later after the car sits for a while. We'll see.
Okay, so I have one other thing I want to do (no, it's not the winking LED either, I actually kind of like that feature)!
Video-in-Motion (VIM)
I have gone through website after website trying to figure out how to get the VIM log-in code. All unsuccessfully. Here is the main link I found explaining it (which it's still confusing to me).
http://audienthusiasts.com/Articles_VIM.html
Here is an excerpt from that page:
For MMI 3G go to:
[5F - Information Electr.]
For the purpose of this sample we will use a made up serial number of : 331CE098765432
The digit order shows what order the number of the serial number will be put in for the security code. i.e. 1 is the first digit 3 would be the 3rd digit of the security code. There are 2 possible codes which is why there are 2 separate combinations shown
Login code #1
Digit order: XXXXX1xxx35X24
Login code #2 (alternative code)
Digit order: XXXXX1xxx234X5
Code #1 = 03625
331CE098765432
XXXXX1xxx35X24
Code #2 =06542
331CE098765432
XXXXX1xxx234X5
Simply take the security code you retrieved and substitute it for the generated code in the instructions below.
So I get my Serial number from the VCDS:
XXXD-0B7614951
look at the explanations of how to get the codes out of that and I come up with:
Code #1:
05614
Code #2:
01491
I think these are right, but it is crazy confusing to me the way they wrote it up on that site. Am I wrong on these codes? I tried both of them and neither work. If I can get the right code to work, I shouldn't have a problem enabling the VIM. Any help here would be much, much appreciated.
2015 Audi SQ5
SEPANG BLUE -- BLACK/LUNAR SILVER
3.0 TFSI quattro
[Premium+ :: Black Optic :: Nappa Leather/Sport Interior :: Carbon Atlas Inserts :: Tech/Nav :: B&O :: Supercharged :: Summer - 21" SQ5 Gloss Black Rims/Dunlop SP Sport Maxx GT :: Winter - 20" RS6 Titanium Peeler Rims/Bridgestone Blizzak DM-V1]
MODS: [ECS Spacers 17.5mm :: BILSTEIN PSS10 Coilovers :: Brembo BBK :: Stop-Tech Rear Drilled Rotors :: EUROCODE ÜSS Alu Kreuz/Sway Bars :: 034Motorsport F&R End Links + Drivetrain Stabilizer Inserts + Silicone Inlet Hose :: SPC Adjustable Control Arms :: ECS Carbon Fiber Engine Cover :: AWE Tuning S-Flo Carbon Intake :: OCARBON Custom/OEM Carbon Fiber Mirrors :: ECode Headlamps :: R8 Oil Cap :: Audi 3.0T Dipstick :: VCDS]
2015 SQ5 **Build Thread** *2015-Present*
2011 Custom Q5 **Build Thread** *2011-2015*
GARAGE:
*2016 Audi Q3 2.0T quattro/Prestige/S-Line
Hanian Blue Metallic/Rock Gray (WIFE)
*2012 VW GLI 2.0T/Tornado Red/Black (Sold)
ThunderDent is offline   Reply With Quote
Old 08-11-2012, 04:35 PM   #2
I need to fish around a little more with the Ross-Tech software, but I would also like to do 3 additional things if the VCDS will do it:
1) Turn off the Chime that dings whenever the passenger gets out of the seat and the passenger airbag turns off. (Wow this is annoying)
2) Set the front fog lights to turn on automatically when the headlights do (when set on auto) or really anytime the headlights are ON.
3) See if there is a way to set the "iNAV" button to work on the flat-bottom steering wheel. That function currently works like it did on the old wheel by just pushing in the roller wheel. The actual "iNAV" button does nothing. I'm sure this can be changed in the VCDS somewhere. It's really not that big of a deal, but something that would be nice to make right.
If anyone has thought on these they would be welcomed as well. Thanks!
2015 Audi SQ5
3.0 TFSI quattro
GARAGE:
Old 08-11-2012, 08:23 PM   #3
Found this site which is really helpful for VCDS.
It'sin German, but Google will translate for us thank goodness.
http://www.stemei.de/pages/coding/audi-q5-8r.php
2015 Audi SQ5
3.0 TFSI quattro
GARAGE:
Old 08-12-2012, 03:40 AM   #4
Hey Thunder,
I'm sorry that I can't help you because I haven't yet purchased VCDS interface and software. I did see something that you mentioned you had changed that really intriged me. Can you please explain how this works being that our fogs are not active bending as the hightlights are in the prestige model....
Thanks.
2012 Q5 2.0T
Brilliant Black/Cardamom Biege
Premium Plus,Nav,B&O,
Advanced Key,Exhaust Tips
johncaravello is offline   Reply With Quote
Old 08-12-2012, 03:41 AM   #5
Download the software from the link on the audi enthusiast page (VMI Instruction page)
The codes work and it's easy from there. If you have any issues send me a PM.
ozfst is offline   Reply With Quote
Old 08-12-2012, 04:34 AM   #6
RCM09's Avatar
Yes do tell us more on this feature....
2009 Q5 Sline/Prestige....Sold
2012 S4 P+ 6MT,Monsoon,Sport Diff,Nav,Sensors,Ad Key,B&O,19's
RCM09 is offline   Reply With Quote
Old 08-12-2012, 05:55 AM   #7
I have no idea if our cars will do this or not. It seemed to really light up my road the other night when I had the fogs on, especially in the corners. Maybe it was a placebo effect where I knew I changed the code and all of a sudden I'm seeing better on the road.
So I did a little more research on it, and it appears that it is a code that when in place, and when you have your fog lights set in the OFF position, that when you turn your steering wheel to the right or left around a turn, that the corresponding single fog comes on to light that corner. I believe there may be a speed limit (mentioned in some forums on the matter) that it works until you get over that limit.
I like running with my fogs on anyway, so that should override this code. I'll need to go out and check to see if this is what mine are doing when they are set to off, but here is a video that explains it better...
2015 Audi SQ5
3.0 TFSI quattro
GARAGE:
Old 08-12-2012, 06:06 AM   #8
Anyone have any thoughts on this mod?
http://www.stemei.de/pages/coding/au...obahnlicht.php
Is this not something that our Q's do already??
Seems like a good safety feature that the headlamps focus the beam and shine farther down the road once you go over a certain speed (68 mph). Thoughts about performing this mod??
Motorway mode utilizes the large amount of light and optimized pages and apron lighting of the xenon plus pig launcher. Using sensors, an automotive electronics is constantly analyzing the speed of the vehicle. After a short time above 110 km / h, the system consists of a car ride and automatically switches from low-beam mode in motorway light mode. Through a special position of the diaphragm in the xenon plus headlights now additional light is focused by an aluminum reflector and thrown far from the vehicle without dazzling other road users. Here, the visibility is more than doubled: from 70m to 150m in low beam mode, motorway light mode. This increase in visibility means at a speed of 130 km / h, a gain of 2 seconds to react to objects in front of the vehicle. Motorway mode increases the driving safety significantly.
2015 Audi SQ5
3.0 TFSI quattro
GARAGE:
Old 08-12-2012, 06:29 AM   #9
spijun's Avatar
I make this mod and work on my Q5
Did you tried VIM-code generator
http://www.motor-talk.de/blogs/scott...-t2617595.html
http://trick77.com/wp-content/upload...IMGenSetup.msi
http://trick77.com/2009/07/18/enable...s-vag-com-mmi/
Serial number: XXXD-0B7614951
Code #1: 05114 NOT 05614
Q5 2.0 TFSI,S-tronic,
Milano leather, B&O, 19" 5-arm polished
Excuse me for my English
spijun is online now   Reply With Quote
Old 08-12-2012, 08:13 AM   #10
Thanks for the generator. Late last night I saw that I messed up that first code. Going to try it later, as well as making that headlight motorway mod.
Similar Threads
Thread Thread Starter Forum Replies Last Post
VCDS DIAGNOSTICS Aman Singh Parhar A8 / S8 (D3 Platform) Discussion 5 09-16-2015 06:01 AM
Instrument cluster replacement Drongo TT (Mk1) Discussion 3 09-12-2015 07:27 AM
2015 Q7 VCDS Gear Indicator Success davidbod Q7 Discussion 0 09-05-2015 12:20 PM
No Start, Need Codes Diagnosis eggsngrits A8 / S8 (D3 Platform) Discussion 0 09-05-2015 10:22 AM
Diagnostic Tool Advice... ttedeschi3 TT (Mk1) Discussion 6 09-04-2015 06:48 PM
Tags
airbag, audi, huntington, light, mmi, motion, motorway, programming, q5, rews, s5, shows, vag, vcds, video, wv
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
