X-Brace Chassis Reinforcement is it worth it?
Good Afternoon,
I was looking into the 034Motorsports X-brace Chassis reinforcement and was wondering if anyone had any experience with it?
What other mods to you have with that?
Is it worth replacing stock to the 034 Motorsports brace?
Thanks
Thanks
I've got a lot of the 034 parts. Brace, drivetrain inserts, sway, and endlinks.
The brace really stiffens up the front. The front is a lot more predictable cornering. Granted I did the sway at the same time, however I can take on/off ramps at 20-25mph faster than I could with stock. I don't get the soft/washed out front feeling anymore and now I only get tire sidewall flex. Haha.
I would recommend it.
Eurocode Alu Kreuz Drivetrain Stabilizer Review
Alu Kreuz Billet Aluminum Drivetrain Stabilizer is it really worth it?
There's a lot of confusion around what the Alu Kreuz or similar subframe braces do. They mostly improve steering feel and feedback as the OEM brace allows too much flex and results in wrong steering input. I suspect those who say they don't feel a difference are not sensitive to proper steering feedback and may have never driven a car that provides good steering feedback or don't drive on roads where it is noticeable. Eurocode summarizes what the Alu Kreuz does pretty well and it really does that in the real world, but it doesn't do more than this. I don't know how much it improves the Q5, but it is a noticable improvement in my RS5 despite that the RS5 already has a beefier subframe brace from the factory.
From Eurocode's website:
- Better steering response- both at the limit and in normal day-to-day driving
- Improved steering accuracy- more “point and shoot” versus a vague steering feel
- Less “play” or sloppiness- better composure on uneven pavement with less shimmying
- Less torsional flex from the chassis (some even report less creaking in the interior)
- Vastly improved driving dynamics along with increased refinement
I had the 034 brace on my A5... I did notice a significant improvement in the steering response during hard driving. There was a lot less front end skittering on bumpy and poorly paved roads. As mentioned above, there is an improved response to steering input and direction. I did not do any sway bar upgrades, just the X-brace. I plan on putting the brace on my Q5 as well, just waiting for some shop time.
1 Post
I should have mine on in a few weeks, so I can report back then.
I am, however, adding sways at the same time, so it may be hard to pinpoint just the brace upgrade feel.
I would suspect this may also be the same reason why some feel a much more dramatic difference then others.
What kind of shop time/labor is involved for x brace install? I just popped on 034's transmission insert/brace and am truly amazed at what difference it makes in getting rid of the clunk under hard shifts in sport/dynamic mode - crazy how much difference it made....
"Do not perform this work using ramps, or with any weight on the wheels!"
Takes a couple hours and just follow the instructions carefully.
