2009 Q5 3.2 - HVAC Blower not working
Old 07-07-2014, 08:36 PM
  #11
spijun's Avatar
Originally Posted by Q5 Bob
Where is the cabin filter located? In the manual they talk about replacing it, but don't have any DIY information. Tks.
Here is all explained
http://www.carcarekiosk.com/video/20..._cabin/replace
Old 07-07-2014, 08:55 PM
  #12
spijun's Avatar
Originally Posted by JoeBlowAudi
I can't get it to fail tonight.
I pulled the filter it's only slightly dirty. With the filter in or out, I don't notice any difference in airflow at the vents.
If you have VCDS to do a scan and see what the problem
Old 07-08-2014, 06:49 AM
  #13
JoeBlowAudi's Avatar
Originally Posted by dscline
I know it may not be much help, but these are the exact symptoms I had in my A4, and they replaced BOTH tbe motor & motor controller. At least that's what the ticket said.
Thanks. I'm kind of leaning toward just replacing both, as the posts I've seen are pretty evenly split.
Still, that's only $500 vs. the dealer at about $1,100.
  #14
Unfortunately, I don't.
I pulled out the glove box yesterday and built a wiring harness that I can place between the controller and the blower motor. Using a multimeter, I should be able to at least tell if the controller is passing the right increasing voltage to the blower motor. If it is, I'm going to assume the controller isn't the problem and only the motor needs to be replaced. If it isn't, I'll probably go ahead and replace both the motor and the controller.
Now I have to wait for the problem to happen again.
Old 07-08-2014, 07:16 AM
  #15
spijun's Avatar
To find someone near you with VCDS may also try the regional forum and the VCDS locator
Maybe it's better and easier
Old 07-08-2014, 01:45 PM
  #16
dscline's Avatar
Do you know if it's that simple? It could be an ECM motor, or use some type of PWM or SCR type control.
Old 07-09-2014, 08:03 AM
  #17
I know that when everything is working, I see current coming from the resistor, and with the motor connected, I can watch the amperage increase between the motor and the resistor as the fan speed increases.
If the blower motor ever stops working again, and the resistor is providing current, I feel pretty confident that replacing the motor is the first step.
If the resistor fails to provide current, then it could be the resistor or something further up.
Old 06-01-2017, 11:59 AM
  #18
Treacyy1's Avatar
Default HELP!!!
I have a 2011 Q5 and my AC has stopped blowing air.
The compressor is kicking in, but I don't have any air blowing out of the vents. I have replaced the Blower, and blower resistor and still no air. I have checked fuses on the driver and passenger side fuse banks and all are good. I need any suggestions that I could try without having to pay mechanic a fortune to do something simple.
Any help or suggestions would be very much appreciated!!
Old 06-01-2017, 04:40 PM
  #19
MurrayA4's Avatar
JoeBlowAudi
"built a wiring harness that I can place between the controller and the blower motor"
If you monitor power and ground and the fault is an open circuit in the motor you"ll see all the expected voltages from the controller but that won't mean a thing.Best bet is get 12v to the blower motor plug and see if it spins.Just be 1000% clear you're on the appropriate terminals otherwise you're going to make a German engineer laugh and pay a German company good money to fix your testing error.
Old 08-15-2019, 05:08 AM
  #20
Lolaloda's Avatar
Default Houston climate is crippling my Q5 and me!
My Q5 is having same problem. I am in Houston Texas, the worst place to be in mid-August with no AC.
Where is the motor controller located?
I am pretty confident its not the blower motor or resistor. What should I check next??
Quick Reply: 2009 Q5 3.2 - HVAC Blower not working
