USB ports in SQ5?
Old 11-04-2013, 04:08 AM
MAMOHT's Avatar
Default USB ports in SQ5?
Hello
Finally took delivery of my SQ5 last Saturday. Sorry, no time for pictures yet.
When I was setting up MMI, I noticed that it showed 4 USB ports as sources. I could not find them anywhere though.
Is is something hardcoded into MMI or the ports in fact do exist?
Old 11-04-2013, 04:19 AM
josedebardi's Avatar
Only way I know of is via the AMI-USB adaptor cable. This gives one port, not sure it is supports a hub.
Old 11-04-2013, 04:38 AM
spijun's Avatar
There are three models for AMI Interface: mini, micro and standard USB
Old 11-04-2013, 04:55 AM
MAMOHT's Avatar
It is showing 4 USB ports with only the standard 30 PIN iphone cable. It is actually detecting them or those are just hardcoded lines to cover all possible scenarios?
Old 11-04-2013, 05:12 AM
spijun's Avatar
This is true because AMI system is used for several purposes, signal transmission , charging, phone calls, GSM antenna, controlled device with the multi-function steering wheel ......
Old 11-04-2013, 02:20 PM
LASQ5's Avatar
I just spoke with my salesman today about this. He showed me where the USB outlet used to be in the arm rest storage area. We noticed there was a little cover over the hole for it. We wondered if it might be prewired for usb and Just needs to be connected. HE's checking with a tech for me.
Old 11-04-2013, 02:46 PM
I looked at this as it would be much more useful in the armrest. My dealer offered to run a USB extension through the tunnel from the glovebox and pop out from the panel you mention but there is no wiring already there.
If you don't have AMI then the panel has a 3.5mm AUX jack BTW. But I think 99% of people either spec AMI or it comes as standard in many regions now.
frybear
13
08-17-2017 04:11 PM
koobah
Q5/SQ5 MKI (8R) Discussion
11
11-08-2013 08:58 AM
LuckyRobJ
02-01-2011 02:10 PM
laurav
TT (Mk2) Discussion
01-30-2009 05:58 PM
Quick Reply: USB ports in SQ5?
