VAG-COM Mods and a 2013/14 Q5
Old 11-10-2013, 06:35 PM
123Audi4me's Avatar
Default VAG-COM Mods and a 2013/14 Q5
I was able to complete many of the "favorite" VCDS mods to my 2013 Q5 without any problems. However, there are several mods that have been listed over the last few years that do not seem to work on a 2013. I assume the same is true for a 2014.
These are the mods that do not seem to be possible with a 2013 using VAG-COM and the Hidden Menu. Has anyone else had any luck with these on a 2013 or 2014?
- Enable battery meter
- Enable CD ripping to MMI Juke Box
- Disable warning about entering phone date while car is in motion
- Change turn-off speed for rear-view camera when changing to drive from reverse
- Enable release of parking brake without foot on brake
- Enable release of parking brake without wearing seat belt
I just downloaded and used the latest VAG-COM software version but these mods either do not work when coding changes are made or are they not even possible due to a different layout. When changes do not work, I restore to the original configuration and I have not received any fault codes, thankfully.
Old 11-10-2013, 11:21 PM
spijun's Avatar
I am following this guidance I made battery meter on A5 MY2014
Maybe can on the Q5 MY2013 because the same platform
http://www.stemei.de/pages/coding/au...adezustand.php
Many forget to do this after the change: reset the MMI
Old 11-11-2013, 07:00 AM
123Audi4me's Avatar
I followed these same steps. But no luck. Isn't resetting the MMI the only way to get out of the Hidden Menu?
Old 11-11-2013, 08:01 AM
spijun's Avatar
If not make the correct restart the MMI changes that you made will not be activated
backoffg
A7
12-13-2013 02:34 PM
123Audi4me
Q5/SQ5 MKI (8R) Discussion
05-19-2013 01:03 PM
ellisinA4
S6 (C7 Platform) Discussion
03-27-2013 01:33 PM
Sia Bani
09-06-2006 08:58 AM
Quick Reply: VAG-COM Mods and a 2013/14 Q5
