Convenience touch key dont work anymore
Old 03-27-2014, 02:39 PM
hollowplayer's Avatar
Default Convenience touch key dont work anymore
I was away for 3 days, now suddenly it doesnt work anymore when i touch the handle. I read the manual, it says system deactivated the convenience feature to save battery. Just wonder how long until it back to normal operation. Thanks!
Old 03-27-2014, 02:47 PM
MP4.2+6.0's Avatar
Run all windows full down then full up w/ switches. That should reset it.
Old 03-27-2014, 02:52 PM
still dont work...
Old 03-27-2014, 02:53 PM
one by one, or all windows at the same time?
Old 03-27-2014, 03:17 PM
MP4.2+6.0's Avatar
Default Now I realize you mean the lock function...
One touch window up-down function was what I described.
Try simply driving and getting battery charged up again. It should return with an adequate charge; this is one of the early things the power management system shuts down if it senses a declining battery charge.
bigger picture though, if you left nothing on, a battery should easily hold almost all of its charge for three days. If not, either suspect a failing battery or some other current drain.
Old 03-27-2014, 03:49 PM
Thanks, still doesnt work. Gonna call dealer and see if they could reset it.
Old 03-27-2014, 05:58 PM
Its weird, tailgate working perfectly. Any ideas?
Old 03-27-2014, 06:26 PM
Xenonista's Avatar
Make sure the second key isn't in the car. See if the other one works better. See if the car will start based on key proximity, or if it's just the central locking. Drive it around the block. Check again.
Old 03-27-2014, 06:50 PM
Another key doesnt work. Remote unlock/locking work as well as keyless start. I guess one of sensor went haywire like mentioned in Audizine.
Old 03-27-2014, 08:13 PM
Cobalt Rain's Avatar
Your cell phone should NOT be in the same pocket with the key, or you will get inconsistent results.
Also, I made a mistake once after being away from the car for a while... Remember that you cannot rest your thumb on the square "pad" while OPENING the car. That will prevent the door from unlocking. Don't touch the pad while opening.
GVG888
02-28-2017 06:11 PM
tr6guy
S4 (B8 Platform) Discussion
03-06-2012 10:49 AM
alcarazj
02-22-2009 09:16 PM
lgd
08-28-2006 01:59 PM
pat3co
08-23-2003 09:11 AM
Quick Reply: Convenience touch key dont work anymore
