Different rotor size for '011 Q5
#22
On 345x30mm at the 8K0 615 123 J
#23
2011 Q5 front brake upgrade?
I see that you had the parts for the front awhile back.
Did you complete the job?
The dealer just informed me that I needed a $650 brake job, so no better time to upgrade b/c it seems like the newer (just a year newer) has significantly better braking; like 14-20 feet better from 60 to 0 !
So I want the bigger rotors and I see that the caliper brackets/carriers are obviously needed.
I looked up the part numbers given and I may have gotten it wrong but 8K0615125A and 8K06151126 seems to refer to the earlier rotor size of 330 MM but there are errors all over the place, it seems.
Which ones exactly did YOU use?
I was looking at the kits from ECS Tuning and they have a kit that consists of just 2 carriers and 2 rotors, which confirms the theory that this is all that is needed.
https://www.ecstuning.com/Cart/?add1...esrep=mpanning
Unfortunately, I don't like their kit and it doesn't even include pads.
Now that I look harder, it seems like they have a kit with drilled and slotted rotors for $489.95 but NO PADS.
https://www.ecstuning.com/b-assemble...8k06983bbk~xs/
I was leaning more towards the Power StopZ23 Evolution available with pads for the $250 range.
Should I go that way and source the brackets elsewhere?
Can I have your intelligent thoughts please?
Thank-you in advance.
Ben
#24
#25
Hi Reggie!
https://www.amazon.com/Power-Stop-K6...KTPM97WS3KHACK
Ben
Ben
Just something to keep in mind.
Brian
jmayfield23
13
05-04-2019 08:35 AM
Tomasz@Startup
09-17-2001 12:45 PM
Jimtunes, what is the optimal recommended enclosure size for the Eclipse 88100 DVC?(in sq ft.)Thanks
Jenner
03-08-2001 07:02 PM
