The Beginning of the End for TDIs in the US?
Was at my local Audi dealer today and was informed that the new Q7 won't be offered as a TDI in the US. This is a change, and wondering if this is part of a larger plan to phase out the TDI in the US completely.
I'm conflicted. If this is true, then on one hand it will drive my Q5 TDI value up. On the other, I'll have fewer options down the road. I'm hooked on the Turbodiesel, and will likely never return to gas.
^ They'll still be available in the EU and AU, as demand there is still high.
Very sad. A hybrid Turbodiesel would be the shiznitz, and not coming in the US.
Sadly, yes. I fear it will take many years for this black eye to heal, and by the time the scandal is forgiven and/or forgotten (if that ever happens), hybrids and other alternatives will be mainstream. The only chance VAG diesels have here is if gasoline prices skyrocket in the near future.
There is no question diesel's reputation has been tainted, but the jury is still out on whether it's tarnished to the point other brands will try to distance themselves from it. Land Rover, for example, seems determined to take advantage of the situation.
Hmmmm. If the CARB/EPA compliance issue is solved reasonably, Audi will bring the TDI in the Q7. I think we would all benefit from the remedy IF it doesn't hamper mpg and performance values very much. Audi has a reputation for changing options mid-stream...VW even more so.
It seems the best hope for current TDI owners to maintain maximum value is for VAG to discontinue the engine here in the States. And that is just sad.
How would you define "reasonably"? For VW to fix the 3.0TDI, we know the engine will: lose power, lose efficiency, cost more, or any combination of the above. They wouldn't have bothered to cheat otherwise.
The 3L is an Audi designed engine and has a auxiliary device that's not allowed in the US but is outside of the US. This isn't nearly the same issue as the 2L above and a software fix shouldn't massively change the way the engine runs or performs BUT it's increased use in a non-designed manner will most likely cause increased wear and tear on those parts thus why it's so important for an extended warranty to be put in place to protect owners from being on the hook Guinea pigs
Club AutoUnion
Ultimately, this is they type of blowback that will drive VW to pull them ...
This Couple Is Driving Cross-Country To Return Their Polluting Jetta To VW Headquarters
