Major complaint - AudiWorld Forums
Major complaint
Old 01-21-2014, 02:13 PM   #1
bpp
Default Major complaint
2 major snow events I been through, windshield won't stay clear and ice forms, impeding the wipers swiping. Can't get the defrost hot enough. Is this a symptom of the diesel?
bpp is offline   Reply With Quote
Old 01-21-2014, 02:23 PM   #2
bob m's Avatar
Quote:
Well, I'm not too far from you and the little driving I did, I had the similar issue - ice forming on the blades and some ice on the windshield.
Perhaps if I had driven longer the front windshield defroster would have cleared the window better.
Bob
bob m is offline   Reply With Quote
Old 01-21-2014, 02:38 PM   #3
AudiWorld Expert
Reggie's Avatar
Has not been a issue with our Q5. And we had some major snow and below zero weather and the car was parked outside overnight for a couple of weeks due to the work being done on the house.
Reggie is offline   Reply With Quote
Old 01-21-2014, 02:53 PM   #4
There is a windshield defrost button. Are you using it? Also, turn your temp up.
acadianbob is offline   Reply With Quote
Old 01-21-2014, 03:40 PM   #5
bpp
Quote:
yes & yes...80 deg temp on the MMI, cranked the fan speed to 11/12 max setting.
I cannot believe I am the only driver with this experience.
The first time this happened around Christmas, I stopped several times within an hour to try clearing the blades.
Old 01-21-2014, 04:40 PM   #6
Make sure that you have super winter blend windshield washer fluid in it and blast the wipers and windshield with the heated fluid. The wipers will de-ice.
johncaravello is offline   Reply With Quote
Old 01-21-2014, 05:09 PM   #7
I've found it QUITE difficult to keep my window clear as well, to be honest. Very easily worse compared to my previous Accord...
Have winter fluid and I feel like I am going through it like water - I need to spray LOTS so that it will completely clear - only to get all ruined and uncleanable a short time later...
Kaitlyn2004 is offline   Reply With Quote
Old 01-21-2014, 05:26 PM   #8
Transfer's Avatar
Did I read somewhere that we have heated sprayer nozzles or something? Anyone know the details?
Transfer is offline   Reply With Quote
Old 01-21-2014, 05:34 PM   #9
I wonder if this is a HVAC setting issue of some kind? A round here we've had a brutal winter so far. Extremely cold, way more snow than normal and no problem with the Q5 to date. I haven't done anything with the settings so no idea what it might be.
Q5 Bob is offline   Reply With Quote
Old 01-21-2014, 05:34 PM   #10
I've not had any issues with my 2014 2.0T in Wisconsin, but I have found it odd that I have yet to notice any air coming from the two center vents in the dash this winter. I use "Auto" mode all the time with a 72F temperature setting. The two side dash vents put out plenty of air and so do the windshield vents. I've assumed that there is some logic built in that re-directs air away from the center dash vents and to the windshield vents when the temps are cold.
This is just conjecture, but I wonder if those with problems are seeing lots of center dash vent flow and not enough windshield vent flow. Perhaps there is a software update that would help.
stash64 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Emissions scandal lawtq A7 57 03-15-2016 05:49 PM
First detail Tom Kenney Auto Detailing Discussion 1 12-08-2015 06:53 AM
Car will not start navy_anav A4 Cabriolet (B6 Platform) Discussion 0 09-30-2015 02:38 PM
2011 vs 2012 A8 Changes Mike_k A8 / S8 (D4 Platform) Discussion 1 09-25-2015 07:21 PM
'16 SQ5, first week report! 800 miles... Bruce B Q5/SQ5 MKI (8R) Discussion 5 09-25-2015 01:11 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
