Oil Level Check Error? - AudiWorld Forums
Old 04-16-2014, 11:17 PM   #1
hanyc42's Avatar
Default Oil Level Check Error?
When I go to Car selection mode and to Oil Level check.
It says "The oil level display is available after approximately two minutes. The engine must be warm and turned off"
When I checked before this message has never popped up during any time and I was able to check the oil level without any problems. Now it shows no matter what circumstances...
Any solution or experiences on this matter??
hanyc42 is offline   Reply With Quote
Old 04-16-2014, 11:36 PM   #2
spijun's Avatar
It's normal when you open the hood of cars
http://forums.audiworld.com/showpost...7&postcount=12
spijun is offline   Reply With Quote
Old 04-17-2014, 12:06 AM   #3
hanyc42's Avatar
I did open the hood a few days ago and it has been like this since.
I am still not understanding why the oil level is not showing up...
DO I have to somehow reset it ?
Old 04-17-2014, 01:40 AM   #4
spijun's Avatar
Everything is explained in the attached PDF : Oil Level Display
You need to wait a little longer sometimes 4-5 minutes
Old 04-17-2014, 04:18 AM   #5
uberwgn's Avatar
The system is constantly checking the engine oil level (dynamic measurement) with the engine running. It assumes that you added oil if you opened the hood. It takes several days, IME, for it to come up with a recalculated value. There is no way to accelerate this process.
You can check the oil level while driving by accessing the MMI once a new reading has been calculated.
If you want a real-time, static measurement: open the hood, engine off, view reading in MMI. I'm quite certain the engine needs to be hot for this to work.
uberwgn is online now   Reply With Quote
Old 04-17-2014, 08:08 AM   #6
hanyc42's Avatar
I have waited long time.... and it has been a couple days.
Still not showing up, thats why I am confused...
Old 04-17-2014, 08:09 AM   #7
uberwgn's Avatar
How many miles have you driven since opening the hood?
Old 04-17-2014, 08:15 AM   #8
After you have driven enough that the car is warm. Turn off the car, then push in the key without your foot on the brake (turn on ignition without starting). Wait a minute or two maybe longer sometimes as Spijun says above. Should be working again.
Did you do that yet? I have to do that every time I open my hood. Works every time.
rdA4WtQ5 is offline   Reply With Quote
Old 04-17-2014, 10:48 AM   #9
hanyc42's Avatar
Quote:
at least 30miles
Old 04-17-2014, 11:22 AM   #10
uberwgn's Avatar
That may not be far enough to log the new values.
You can always open the hood, key on, engine off and get an instant reading as an alternate.
Thread Thread Starter Forum Replies Last Post
:: ECS Tuning :: NEW!! B8 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B8 Platform) Discussion 14 12-23-2016 04:46 AM
Q5 Hybrid System Fault lazaroni77 Q5/SQ5 MKI (8R) Discussion 2 12-23-2015 03:47 AM
Thanks for helping! (New D3 owner) LONG CPLYONS A8 / S8 (D3 Platform) Discussion 7 09-07-2015 08:19 PM
:: ECS Tuning :: NEW!! B7 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-01-2015 10:16 AM
:: ECS Tuning :: NEW!! B8 A5 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-01-2015 09:27 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
