Oem wheels on 2014 Q5 hybrid
Old 05-22-2014, 03:17 PM
Massprince's Avatar
Default Oem wheels on 2014 Q5 hybrid
I own a 2014 Q5 hybrid and I plan to install 4 oem 20" turbine wheels. I'm wondering if anybody had problems with installing oem and tpms?
Old 05-23-2014, 06:56 AM
Steppenaudi's Avatar
Audi uses a TPMS approach that doesn't require a sensor in the tire. The approach uses the anti-lock brake and other sensors to detect that a tire has low pressure via vibrations.
So don't worry about TPMS sensors when you change wheels.
Old 05-23-2014, 08:07 AM
MP4.2+6.0's Avatar
+1, as a Hybrid owner using a second set of 20's.
Old 05-23-2014, 08:59 AM
Massprince's Avatar
Thanks I almost cancelled the order
Old 05-23-2014, 09:06 AM
Chuck2006's Avatar
So whatever wheel I will use for winter, if I pick the TPMS sensor option (in Canada), I won't have to pay more for TPMS sensors ?
I should have ticked that box....I like knowing my tires are low on air, but hate the maintenance usually associated with these sensors.
Old 05-23-2014, 09:37 AM
Massprince's Avatar
I bought 20" turbine style with Michelin tireshttp://http://www.usarim.com/20-inch....html?___SID=U
To replace my current one
Old 05-23-2014, 09:39 AM
Massprince's Avatar
Here is the correct linkhttp://www.usarim.com/20-inch-oem-st....html?___SID=U
Old 05-23-2014, 10:02 AM
abcabc's Avatar
The wheels on the link look nicer than OEM for some reason.
Old 05-23-2014, 10:25 AM
Massprince's Avatar
Wheels on the picture are genuine audi 18"
Old 06-01-2014, 01:12 PM
Massprince's Avatar
Its finally changed to 20". Thanks for your helpful info
Quick Reply: Oem wheels on 2014 Q5 hybrid
