what is the best snow tire method?
Old 08-15-2014, 08:21 PM
  #21
AudiWorld Expert
ex-quattro PETE's Avatar
No problem, metta. I'm actually jealous of your location and the fact that you don't have to put up with this white crap. It severely cuts into my biking schedule.
I'll be most likely getting the Nokian Hakka R2 for the wife's Q5...
Old 08-16-2014, 06:38 AM
  #22
ND40oz's Avatar
Originally Posted by timlocke
All season tires are really 3 season tires.
All season tires lose most of their grip in the cold. From about 7 deg Celsius on down they become more like hockey pucks than tires.
This is incorrect, but it's exactly what happens with summer tires. An all season tire compound is designed to also work well below 40F/7C, that's the whole point of the all season. You compromise some warm weather performance for a compound that works in below freezing temps. Tread design will dictate how well they actually perform in the snow and ice, something like a Conti DWS will do better in the snow then the Pilot Sport A/S 3 because of the tread design.
The inverse is true but in a different way. Real winter tires will wear fast in high temps and can overheat because of the soft rubber and tread patterns that are not optimized for running hot.
Correct, with an all season you also compromise some winter performance for a compound that doesn't get too soft in warmer weather. Winter tire compounds combined with things like siping gives you a tire that works extremely well in the winter but feels like you're driving on jello in the summer.
Old 08-16-2014, 08:01 AM
  #23
timlocke's Avatar
Maybe we have different definitions of winter!
Conventional all seasons start to lose their performance below 7 C or 40 F. Certainly some are better than others and there are a new breed of 'all weather' tires with a ice capable tread pattern with lots of sipes but with a rubber that can manage higher temperatures...by all accounts these do work well enough all year around for medium winter use.
Winter Tire Safety Tips | Tire Safety Below 45° | Discount Tire
A study conducted by the Quebec Ministry of Transport showed that a proper winter tire can improve braking up to 25 per cent over an all-season radial tire, and can improve collision avoidance by approximately 38 per cent.
And from General Tire a manufacturer of tires.
http://www.generaltire.ca/pdfs/Benef...interTires.pdf A quote
"The rubber compound used in winter tires is relatively soft. Generally speaking, the rubber in an all-season tire starts to lose elasticity and harden at a temperature of 7ºC, greatly reducing grip.
At -15ºC, this type of tire will have lost all its elasticity, whereas a winter tire
will only harden at around -40ºC; therefore retains its elasticity for much longer."
Old 08-16-2014, 08:33 AM
  #24
metta's Avatar
Siping/sipes. I've now broadened my vocabulary in addition to my understanding of winter versus all-season tires. You guys are a veritable font of knowledge! Seriously, I learn a lot from these forums and all of you . . . Thanks!
Old 08-16-2014, 11:59 AM
  #25
ND40oz's Avatar
LOL, or maybe a different definition of the hardness of hockey pucks :P
Yes, a winter tire will perform much better then all season in sub 7C temps, there's no debating that. If you have 4+ months of weather where it rarely goes above 7C, then winter tires are a must buy. Here in CO, I could leave in the morning with 3 inches of snow on the ground with the temp below freezing and drive home that afternoon with it in the 60s and sunny with all of the snow already melted away. With that type of weather, I prefer to stick to a UHP All Season then worry about burning up winters in one season because the weather fluctuates so much.
http://www.tirerack.com/tires/types/uhpas.jsp
Ultra High Performance All-Season Tires
You want all-season versatility (including light snow traction) and are willing to trade some dry and wet traction and handling to get it.
Branded with the M+S symbol, these ultra low profile tires are designed to provide year-round traction (even in light snow) through tread designs and compounds that remain more flexible in the cold weather to help blend all-season traction with very good handling and high-speed capabilities.
It really depends on what your climate is and what your needs are.
Old 08-17-2014, 03:28 AM
  #26
timlocke's Avatar
@ND40oz. I think we agree. Even in relatively balmy Southwestern Ontario we rarely get weather like that except in spring but we do get a lot of just below zero 'warm' ice and snow which is much more slippery than cold ice and snow and modern tires like Blizzaks and the Xice-3 work their best under those conditions and Hakka Peliitta snows are better in severe cold...it is a complicated business, this winter stuff.
@metta. The sipe thing. They 'pump' away the microthin layer of water that is always on top of ice to let the rubber compound of the tire actually touch ice where it might find some grip. They will also help wet grip above freezing as well.
Old 08-17-2014, 01:11 PM
  #27
carfan1111's Avatar
thanks guys i will get a dedicated tire wheel set
do you guys have recommendations on snow tire? goodyear vs yokohoma vs blizzak?
yokohoma is the cheapest at my local store
Old 08-22-2014, 04:28 PM
  #28
Redd's Avatar
If you mount and unmounts the tires each season, I would expect some expensive wheel damage in short order because most shops wind up damaging alloy wheels. Plus, every time you stretch the bead and reseat the tire, increases the chance it will not be seated cleanly and as a result the tire will have a slow leak. Or the tire bead itself may be damaged.
Four tires on, four off. Twice a year. That's sixteen chances to damage something every year, and the tires may last you four years? Sixty four chances for damage?
Personally, I've always had my snow tires mounted on extra wheels. And if there's a sudden storm or I need a spare spare...I can swap an entire set on the car in under an hour, with no special tools or jacks.
Look for a set of aftermarket wheels, or a set from a junkyard, if you want to save on those.
josgarc
Q7 MK 1 Discussion
11
12-01-2018 07:55 AM
517
Want To Buy - Archive (NO NEW POSTS HERE)
11-22-2015 08:39 AM
ikold
Wheels & Tires Discussion
09-15-2014 07:15 AM
Roger @ CA
Mid Atlantic Discussion
10
01-07-2005 11:00 AM
husky
Canadian Discussion
12-02-2003 04:22 PM
Quick Reply: what is the best snow tire method?
