Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
2009+ Q7 w/ 3rd Row Seating...
Old 04-26-2012, 06:03 PM
  #11
AudiWorld Expert
iconoclast's Avatar
that is why it is there and was not present on the previous years however the metal buckle is still out in the open and may bang/rattle against the trim. on the previous models it locked into a receptacle and the straps did not move and were not in the way. curious why they did away with this feature.
Old 04-26-2012, 10:12 PM
  #12
Hasser's Avatar
Originally Posted by Jusforfun
Insert the ignition key into a slot in receiver of row 3 belts. This releases the entire belt to retract all the way.
exactly what i was saying. good pics!
Old 06-26-2013, 06:37 PM
  #13
AudiWorld Expert
iconoclast's Avatar
very annoying that 2009+ models do not have this feature... putting cargo into the Q7 today and kept getting stuck on the belt straps. 2007 had it the best with the locks underneath the third row tucking away everything.
after i was done unloading the cargo i opened up the third row and buckled the seatbelts then tucked the straps into the restraints found on the side panels in the cargo area... now everything is tucked away nice and tight and out of the way.
Old 06-27-2013, 03:55 PM
  #14
Ultimate Keyboard Warrior
Force-1's Avatar
Originally Posted by ithinkmac
In my '10, there's a slit that's part of the trunk area that you can slide the seat belt into, which holds the buckle above the cargo cover. The slit also helps to keep the seatbelt nicely clinging to the side, so no loose slack or anything. I think that's why it's there, although I didn't read the manual. Maybe it's for another purpose, but that's what I'm using it for.
-ThinkMac-
Same here. I have clips on the side used to keep the belts out of the way.
Old 06-27-2013, 04:18 PM
  #15
AudiWorld Expert
iconoclast's Avatar
right, it keeps the belts to the side but the buckles themselves are still exposed when they were not on the 2007 and 2008 models as shown in the photo earlier... not sure why audi decided to delete this feature but i am going to guess it's cheaper.
Old 06-28-2013, 04:17 AM
  #16
Force-1's Avatar
Another plus for a cargo mat is it helps to keep the belts out of the way.
Old 09-11-2014, 04:38 PM
  #17
AudiWorld Expert
iconoclast's Avatar
my major gripe with the Q7 is every i load anything into the cargo area the seat belts get hooked on the packages or items and then hook from the cheap plastic hooks that are supposed to hold them in place. i have tried several ways to get them tucked in better and nothing. before i unbolt the seat belts completely and tuck them into the headliner does anyone on here have any suggestions?
Old 09-12-2014, 04:39 AM
  #18
Edd W's Avatar
Mine just stay up in the receptacle in the rear pillar - do yours drop down from there?
Old 09-12-2014, 09:35 AM
  #19
AudiWorld Expert
iconoclast's Avatar
mine come out of the headliner but they're latched into the chassis and then a plastic hook is supposed to hold it back from the cargo area but doesn't do it very well.
Old 04-01-2015, 04:39 PM
  #20
AudiWorld Expert
iconoclast's Avatar
*update: solution i came up with for 2009+ models is to set up the third row in the upright position, then latch the seat belts, then pull some slack on the belt and lower the seat into the locked position then slide the belt under the plastic clips. this was the easiest method. if you want to go a step further you can open the plastic clip that is attached to the belt and then clamp the shoulder belt to the lap belt and then lower the seats. both options results in seat belts that do not flap or get loose in the cargo area.
as far as getting caught on items it will happen no matter which way you try to tuck them away.
unfortunate design flaw for the NAR market. ROW gets detachable and retractable belts in the headliner.
amorak
Q5/SQ5 MKII Discussion
09-21-2017 07:15 AM
audijeff1983
Q5/SQ5 MKI (8R) Discussion
12-11-2015 08:07 AM
GomerPyle
Q7 MK 1 Discussion
04-07-2014 06:56 PM
-M3=Lunch-
22
02-01-2006 08:25 PM
Just Gizmo
06-03-2002 05:05 PM
Quick Reply: 2009+ Q7 w/ 3rd Row Seating...
