Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
2010 Q7 Tdi - Coolant Leak
Old 09-16-2010, 10:49 AM
  #11
Audiworld Senior Member
Edge's Avatar
Originally Posted by FFN
When in for my first service @5000 miles in May, Audi performed two services that were required by Audi, one was replacement of the coolent pump and the other sounded similar. They detected a leak during service that I had not noticed and told me there was a service bulletin for both issues.
This past Saturday, I noticed a large puddle of liquid under my parked 2010 TDI (11,000 miles). As I was driving, the coolant warning light came on. I took the vehicle to the dealer and they diagnosed a leaking Coolant Pump; which was replaced.
Seems to be a pretty widespread problem at this point.
Old 09-16-2010, 01:31 PM
  #12
wabisabi's Avatar
Originally Posted by b6s4eastbay
I just found out that my Q7 with 10k miles on it has a major coolant leak. The tech at livermore audi has informed me that they are unable to diagnose the source, and may have to take the engine out.
I'd get a second opinion from another dealer (with different ownership).
My 2009 Q7 TDI received the following at my 25k service:
Water pump (059-121-012-A) and associated clips, hose and tie wrap.
Pump for exhaust gas recirc cooler(V400 19 45 55 99 130TU) and associated hose.
This was mandated by Audi and my Q7's water-pump had not failed at all but was replaced due to a higher likelihood of future failure. It is a common failure for any VW\Audi group vehicle with the 3.0 TDI engine.
Old 09-18-2010, 07:17 PM
  #13
Q7Q7Q7's Avatar
You're lucky. Same mystery leak in my 07 4.2 engine resulted in a complete engine replacement at 30K....my problem was related to a cracked engine block.
Old 09-18-2010, 07:31 PM
  #14
NYCTaxiMan's Avatar
If other 2010 Q7 Tdi owners have experienced similar issues, please ping me.
Thanks,
Asim
My 2010 Q5 busted a leak while on the road today. I was able to get it towed to an Audi dealership. As I was explaining my problem to the service consultant, she responded that it was my water pump. She indicated that its a known issue with some of the Q5 units. In the end, after 4hrs, the pump was replaced and I was back on the road.
Water Pump (06E-121-005-G)
Old 08-17-2016, 05:49 PM
  #15
Edin Rekich's Avatar
Default 2010 Q7 TDI Audi
I had a leak on my q7 tdi for days and i fond it, the heat shild that sits on top of the engine causde it
Old 10-31-2018, 02:44 AM
  #16
Bongani45's Avatar
You are quite correct had to take my 2013 audi Q7 from Audi garage to a private mechanic to have my fuel rail fixed, in turn out to be poor workmenship, when they were replacing one faulty injector they did not tighten the bolts holding the injectors properly but already asking for R18.5k to replace the whole fuel rail system
Old 10-31-2018, 02:50 AM
  #17
Bongani45's Avatar
Originally Posted by adriangroom
Funny how when you follow most of these threads you keep seeing the same old problem mentioned again and again and again... the techs can't diagnose the problem.
Having experienced this myself through my own local Audi dealership (I could write a book on them) I'm beginning to wonder if any Audi techs can do anything other than operate a diagnostic computer program because if it doesn't show up on screen or on a TSB they don't seem to have a clue where to start looking... or am I being harsh?
08-18-2016 03:49 AM
Old 10-31-2018, 05:01 AM
  #18
Bongani45's Avatar
I am trying to locate where exactly this leak was found in the engin
Old 12-21-2019, 11:11 AM
  #19
Darryl Smith's Avatar
Default Coolant Leak
I just discovered I have this problem this morning on my 2010 anybody have the part number for the coolant line?
Audia889
02-08-2024 02:12 PM
dolphin_grey
A4 (B7 Platform) Discussion
02-20-2007 07:04 PM
Butane04
15
03-15-2005 11:56 PM
Digger Killer
12-25-2001 03:48 AM
Evzen
Performance and Tuning
07-10-2001 02:09 PM
Quick Reply: 2010 Q7 Tdi - Coolant Leak
