2011 Q7 TDI - Engine Light - AudiWorld Forums
Q7 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Old 03-09-2011, 10:50 AM   #1
Default 2011 Q7 TDI - Engine Light
Hey everyone,
Here is the problem I am experiencing.
The engine light has been coming on in the car since October. Since I live in cold climate, my heater is always on. I have noticed whenever the car is idle for over 5 minutes with the heater on full, the engine light comes on.
I took it to the dealership 3 times already. The first time, they reset the light. The second time they did a thorough diagnostic and found nothing wrong. The third time, they diagnosed it and found the knock (or NOX or NOK) sensor to be the cause, they replaced the sensor did a 300km road test and found nothing wrong. A few days later after I drove it around...the engine light came on AGAIN.
What do you guys think? Any suggestions?
9.27 is offline   Reply With Quote
Old 03-09-2011, 10:57 AM   #2
I think its the problem with the sensor wiring. The dealers would not have checked the wiring did they.
Pikachu K S is offline   Reply With Quote
Old 03-09-2011, 03:29 PM   #3
Is there a leak or damage on the exhaust pipe of the Aux heater?
Is there a fail on the sensor programme of the Aux heater?
Does the Aux heater shut off after 5 to 10 mins after startup.
I just wonder if the engine is picking up fumes from shut down of the Aux heater. Mine shuts down with a black puff of exhaust if it purges when shut down occurs during a flame cycle. It is much more obvious if it occurs when the car is stationary. I do not usually leave my car idle that long unless it is frozen... Ireland.
Jusforfun is offline   Reply With Quote
Old 03-09-2011, 07:10 PM   #4
Audiworld Senior Member
Edge's Avatar
This *seems* to be a common issue, several of us have been hit with this intermittantly. I have had it happen three times. Check out this thread: http://forums.audiworld.com/showthre...&highlight=NOX
No answers, but yes, it's a known issue.
Edge is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
EPC Light on... Coolant Leak ... ECM needs Replacing Audifastdaddy A8 / S8 (D4 Platform) Discussion 10 07-07-2016 05:43 PM
Reverse lights(2 part question) Bklyn_Quattro Q7 Discussion 3 11-12-2015 03:20 AM
2011 2.0T Misfire + EPC On Start Q-Branch Q5/SQ5 MKI (8R) Discussion 5 11-06-2015 02:25 AM
bad engine Dion Block Q7 Discussion 3 09-30-2015 09:30 AM
OEM Exhaust Tips for the 2.0T Buckwheat2088 Q5/SQ5 MKI (8R) Discussion 0 09-28-2015 07:26 PM
Tags
2006, 2007, 2011, audi, check, cuts, engine, enigine, issues, light, lights, problems, q5, q7, tdi
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
