Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
2014 Audi Q7
Old 04-21-2012, 04:47 AM
Oldmxnut's Avatar
Default 2014 Audi Q7
After a quick browse of a few of the reports floating around, the new version is sounding good. I like the twin turbo 4.0 V8 rumour. Add that to being 650 pounds skinnier, its performance should ensure that even a drop bear would leave a stain.
Old 04-21-2012, 05:05 AM
Jusforfun's Avatar
OK so I figured out the Drop Bear interesting, never heard of it before (and yes it looks like a mean Koala)
but I dont think that expression travels. Are you running over it cos the car is so fast and even a drop bear couldnt get away?
Old 04-21-2012, 05:56 AM
Oldmxnut's Avatar
.. wrong sort of drop bear. But you are on the right track, so here are some more clues
When the "official" drop bear attacks, he drops sliently and doesnt leave a trace from wence he come, but as he is a fat little bear, when he hits the ground, the sound he makes is a "plop"
now consider the above in the context of a bowel movement.
so if you were in a pub a little aways off the beaten track, and the road corragations had packed it all in over the last 1000k's... you would casually say to your mates as you rose from the table to vist the loo... "im off to let a few drop bears go"
Old 04-21-2012, 06:02 AM
Goodlivn's Avatar
not sure where they will find 650lbs of fat to trim unless they drastically change the body style and look. personally i like the heavy manly look the Q7 has now. im not averse to any changes but if it looks anything like that slimmed down 2013 prototype pic that was floating around the board a few months ago, this will be my last Q7
Old 04-21-2012, 06:36 AM
K2audi's Avatar
It really shouldn't be a problem. Weight has always been the Q7's achilles heel...they are going to move to the modified platform that the new Cayanne is on with lighter chassis components and lighter and stronger body stampings. They took 400 lbs. out of the last gen Cayenne.
Old 04-22-2012, 07:12 AM
Jusforfun's Avatar
charming... so you are saying should be frighteningly quick.
Old 05-05-2012, 09:00 PM
Oldmxnut's Avatar
Reading a recent reveiw on the S8 with the 4.0 Bi- turbo. It apparantely generates 520HP and 650NM. Given this sort of performance and the technology around dropping one of the banks for fuel efficency, does anyone think the V12 in the Q7 will continue to be part of the line up?
Further will we see a "S" version in the Q7 range?
Old 05-06-2012, 06:59 AM
arkbbq's Avatar
Default Engines and S's
Engine discussion from Automobile Mag's recent "Deep Dive" on Q product strategy:
"The Q8 will be derived from the 2014 Q7, but it won't adopt the lesser model's new four-cylinder base engine. Instead, we should expect to see two gas-powered V-6 engines delivering 230 and 300 hp, a 250-hp 3.0-liter V-6 TDI and a 400-hp 4.2-liter V-8 TDI, plus the S Q8 boasting the same 550-hp twin-turbo 4.0-liter V-8 from the S6/S7/S8. In addition, spies are predicting two plug-in hybrids: one mated to a gas-powered four-cylinder TFSI unit, and the other paired with a V-6 TDI motor."
No mention of a V-12 or an S Q7. Also, even after shedding 800 lbs., it's hard to imagine the Q7 with a four-banger.
See link:
http://www.automobilemag.com/feature...s_the_q_range/
-ark
Old 05-07-2012, 01:05 AM
Oldmxnut's Avatar
Thanks for the link. I hadnt seen the article before. So from the sounds of it, we have to wait until 2016 for the Bi - Turbo.
It makes sense though and history is proof that the order is.., first... new shape, old engines... second... same shape, new engines.
Old 05-16-2012, 01:11 PM
ercstar's Avatar
Id like to suggest the interior will follow a similar upgrade like the new A6...in terms of the instrument dial layout and MMI remaining same as current updated q7 models.
Also we should see the surround cameras coming soon too (i.e. additional camera on the front)...
samchuang33
Q5/SQ5 MKII Discussion
9
02-27-2019 11:08 AM
OldSkewS4
Audi Original "S" Cars
10
10-02-2008 03:27 PM
Jason Teller
Audi News Forum
10-22-2007 08:56 PM
the senator
10
07-30-2005 02:07 PM
bigalk (back in UK)
01-09-2003 05:30 AM
Quick Reply: 2014 Audi Q7
