22 Rims for 2011 Q7 S line prestige
Hi guys, have a question. Looking for new 22 rims for my Q7. Found ones, but in one website written that will not fit, in other one that will fit. And i found pic the same wheels on Q7 , so it should fit then...
Question: what size 22 rim should be that it will fit?? and what tire size you suggest. Mine Q7 without air suspension with OEM 20"s
On add written 22x9.5 high offset.
For 22, go with 285 35 22
As iconoclast said, maximum offset for 22x9.5 rims is 25. Anything more than that is safe. (25-50). The lower the number, the more they will stick out of the fender
AudiWorld Expert
285.30.22 would keep you as close to the overall diameter your vehicle came with but i would code the correct tire size once you change wheels/tires. it will keep your electronics in order.
Tire size 295/35-21 285/30-22
Section width 295 mm (11.6'') 285 mm (11.2'')
Sidewall 103 mm (4.1'') 86 mm (3.4'')
Tire diameter 739 mm (29.1'') 731 mm (28.8'')
8 mm (1.1%) shorter.
Rim sizes 21x9 to 21x11 22x9 to 22x10.5
Circumference 2320 mm (91.3'') 2295 mm (90.4'')
Revs per mile 693.5 701.1
