Adaptive Air Suspension Compressor
#11
Prior to having the problem I didn't have any codes relating to a leak. I was assuming that the leak code is because the system is empty?
I'm running the compressor on another battery manually and its pumping away but the car isn't going up. Should it?
I've let it run for about 3 mins but nothing happens. How long to pump the car up?
What makes me wonder at the compressor is the amount of current it draws. Its making 1.5mm cable physically hot too touch and completely melted some smaller cables.
I've not noticed anything in VCDS specifically related to the air struts. Is it only in VAGCOM?
Thanks
Jason
Thanks
Jason
Your code is 001 - Upper Limit Exceeded. for temp.
With my research I have posted a troubleshoot chart. It for a Treg, but it has the same system you have for a Q7.
it is sounding more as your Air supply unit with solenoid
valve block
Check out guide for step by step troubleshooting
TREG AIR SURP.pdf
#12
be careful doing manually, cause the ECM is not reading how hot your compressor is getting. This is why the Q7 has the temp seņor for auto shutoff.
valve block
Attachment 45700
valve block
Attachment 45700
I've ordered a new compressor and i'll report back on Thursday.
#13
Ok - so new compressor has changed nothing... :-(
Still showing the same faults including the temp fault which is odd considering it came with a new temp sensor.
The compressor doesn't run at all.
Is there a fuse somewhere?
#16
Before i start taking seats out...
Does anyone actually know if the following error prevents the compressor from firing?
01583 - Leak in System Detected
#18
You have a good leak in your system. The best way to check your system is by lifting the car off the ground, by jacks or a lift. Turn on your system and see if all four air bags start to full up. If it does not start you going have to jump it again. If it runs then you have burn out your relay again, replace it and try again with the car on jacks or a lift. Now Sprayed soapy water around the air resevoir, air lines and control valve with the compressor running and see any leaks/bubbles. Now with the system running lower the Q7 and your system should stop, causing air system malfunction the motor to run for long periods of time, an internal sensor detects the overheat condition and shuts down the compressor circuit over heating the compressor. Your compressor is working correctly which the over temp sensor shutting down your system.
Now if you do not see any leaks now you have to start with your struts find out which one is leaking inside. The diagnosis is pretty easy in this case. The system would attempt to level the suspension, and the strut was holding air well enough to pump up - but would lose it rapidly causing the pump to recycle . . . recycle . . . recycle. Visual observation (and listening to the air leaving the strut) made locating the problem rather simple. If you have one you can send it down to Arnott for repair will be cheaper than buy a new one.
if you take it to a dealer He will replace a lot of components shot gun blast to get your system stared and fix, unless you have a good one with good troubleshooting techs.
on pg 7 of attachment examples of a bad strut.
insp strut.pdf
Good luck.
#19
The Audi techs said to Replace Compressor, Relay and Control Valve Unit from the Start. You have a new compressor, but need to know all fuses and relays are good. right now you have also a new relay, but you could have burn it up when you jump the system. UNK on the fuse. Audi tech always replace the relay every time when you replace a compressor and a control valve.
Attachment 45775
Good luck.
Attachment 45775
Good luck.
One last thing....
Anyone know how to get the bushes off the original compressor?
J
#20
Thanks,
