Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
2014 Q7 TDI Oil Change -- easy
Old 03-13-2014, 07:10 PM
Qaudi's Avatar
Default 2014 Q7 TDI Oil Change -- easy
Just completed the first oil change on the Q7 TDI.
Drove up on a set of Rhino ramps and then removed the front cover under the car. It has a small black drain bolt (6mm allen wrench hole) at the bottom of the black oil pan. The oil filter is in the engine bay, after you remove the plastic engine cover, it is right there in front of you. You will need a large adjustable wrench or pipe wrench to get the oil filter cover off.
I used Mobile-1 5w-30 oil (there is only one that is approved with VW-507 spec from pep boys @$12/qt) The oil filter was Audi OEM @ $15).
It took 8.5 quart of oil and the whole process is very straight forward I didn't even take photos.
As for those of you who are wondering what the differences are among VW 505, 506, and 507 spec oil, here is what I found on another site:
505 = fixed interval oil
506 = flexible service interval oil.
507 = universal diesel standard for both fixed & flexible service interval.
Old 03-14-2014, 12:22 AM
lawtq's Avatar
Agreed in your point that there was no need at all for pics. Very easy. Did the same for my 2010 q7.
Changed my air, pollen and fuel filters too. All easily accessible also. Good design. I can get 507 spec oil very cheap, castrol edge 5w 30 for £30 8 litres, i have a friend in the industry, and all the filters, 4 altogether for £40. So I'll be doing this d.i.y about 3 times a year to keep that engine as clean as possible
Old 03-14-2014, 05:55 AM
Edd W's Avatar
One oil change per year is fine, there is no real benefit in changing more often unless you do 20k miles p.a.
Old 03-14-2014, 05:15 PM
lawtq's Avatar
Oil so cheap, I'm gonna keep doing it. Especially on a diesel.
Plus.... It's bloody enjoyable doing it
Old 03-15-2014, 04:11 AM
OBP
OBP's Avatar
Did you have to change or replace your adblue ? Dealer says their schedule is to replace every 15k miles or once a year.
yvantheterrible
A4 (B9 Platform) Discussion
202
03-04-2023 04:25 PM
sparkster
15
05-31-2011 08:49 PM
DennyDude
Audi 100 / A6 (C4 Platform)
17
09-11-2008 04:48 AM
racer-genx
Audi A3 / S3 / RS 3
03-29-2006 11:17 AM
MDIRADS
13
02-12-2006 09:03 PM
Quick Reply: 2014 Q7 TDI Oil Change -- easy
