Any Issues with using a higher profile tire?
#11
Sadly, every thread that mentions the ability to adjust tire circumference runs to a dead end
I'd LOVE to know how to do this with the 2015 (3G+). I've exhaustively searched the VCDS settings and secret menu to no avail.
It may be adjustable on the older 3G models, just not the newer ones (yet).
#12
AudiWorld Expert
i don't recall off the top of my head and i don't have a q7 anymore to quickly scan for you in the garage. i know it is there... i remember seeing it. it is the overall wheel and tire size in mm (iirc). i have a vcds/vagcom if someone wants to meet up i can browse through the modules or i can sell the cable to someone if they need it. i do not have any use for it at this time.
#13
In 13 years on AW and Vag-Com mod lists out the kazoo, I've not seen a one available to change wheel/tire circumference. My guess is you were thinking of the DIS fuel consumption display mod that can compensate for different sized tires and incorrect readings compared to actual mpg measurements.
#15
AudiWorld Expert
new X5 50i m-sport for the time being.
#16
My vehicle, a 2007 Q7 3.6 Premium, is equipped with the optional 19 x 8.5 wheels. Factory tire size is 265/50-19. I replaced them with 255/60-19's, which is the same size on the Buick Enclave. This size looks better because it fills in the wheel well gaps and rides smoother--not to mention costing 77.00 USD less each. This size works out to the equivalent of a 31 x 10.50 offroad size tire.
I have ZERO issues with running this size, the SAT NAV works normally, and I have no issues with tire pressure monitoring system. So, different size tires on the Q7 are fine in my opinion.
LCP
46
04-01-2004 02:50 PM
RobertG
Wheels & Tires Discussion
07-31-1999 04:51 PM
