Blinking Dash Lights, No Start, and Key Stuck WTF?
Coming down the highway after a 3 hour trip, gauges and dash lights start going on and off, windows don't work, crazy things start happening, but car is still running fine, pull over, shut car, re-start, car starts no issues, get home, turn car off, nothing works, no lights, won't start and key won't come out of the dash. Maybe some kind of anti theft , I'm stumped, car is completely dead now. 65,000 trouble free miles, now this.
AudiWorld Expert
key does not come out of ignition if power is dead.
guessing battery dead or alternator dead or bad ground but very difficult to tell without codes but start there. once you scan you will most likely have a cascade of fault codes. save them then clear and see which return.
Jump started it, fired right up, opened up battery box all looks good, charged battery and it took it, shows 14.1 volts charging good. The only code it shows after clearing is steering column alignment ? I'm stumped as to why it died while driving 3 hrs. on the highway, even if the battery was a little down 14.1 should have kept it charged ?
AudiWorld Expert
Look for loose terminals, corrosion, or perhaps failing alternator. scan for codes and you will most likely have a cascade of fault codes. save them then clear and see which return.
I jumped it and got it running, so I could move the seat to access the battery, the I charged the battery overnight,Vag Com it's showing charging fine and no codes have showed, it's been 10 ten days and running great, very weird !
Muzza668
Q7 MK 1 Discussion
05-20-2013 10:03 AM
