CEL 2008 Q7 3.0 TDI
CEL 2008 Q7 3.0 TDI
Hi all
Only had my Q7 around 5 days. Went to take it for an mot today and it was fine. They were carrying out the MOT test and revving the car while checking the exhaust.
When i went back in the car the CEL was illuminated.
I asked them what that was about but they said that they had nothing to do with it.
It hasnt affected the drive at all but has really made me upset considering ive not had the car too long.
can anyone advise on what i can do or what it can be?
thanks
thanks
well funny thing....took my car to get it washed. After it had been cleaned, started up and the light is no longer illuminated...
Is this something i should be worried about? Is it normal for the light to disappear intermittently if it is the inlet manifolds?
thanks
thanks
But you still have the code in your ECM which needs to be deleted (clear) with a VAG.
After clearing the code then wait an see if it comes back.
So i got it on a computer to check what it could be.
Although the light has dissappeared and not come on since, the diagnostic threw the following code
ECU: E8
P2011
Intake manifold runner control circuit /open (bank 2)
I have cleared the code but what could this be? Is it something i need to get checked?
ECU: E8
P2011
Thanks for the code JonnyKann
This is what you have. If the wiring and volts check out find then it is the intake flap motor v275)
Intake manifold flap air flow control valve 2, electrical fault-V275-Intake manifold flap 2 motor. the right bank is bank 1 and the left is bank 2.
V157 is the flap motor for bank 1 which is shown in the workshop manual as being on the right of the engine and V275 is shown on the left, this is of course as viewed from sitting in the car looking forward.
Since you just had a MOT check and see if the Tech disconneted the plug and never mad sure he put it back on correctly.
The plug is a bit of a pain on bank 2 because it's on the bottom and close to turbo shield.
two attachments one for P2011 and the second on for troubleshooting.
Q7 Intake Flap Motor and Intake P2011 .pdf
Q7 P2011.pdf
Below is a video on the location. If you get the code again I recommend to replace the part instead of repairing it. New parts last a lot longer.
Volkswagen Audi Seat Skoda Parts - ESHOP - Service Car VCDS Diagnostics
Hope this helps
Q7 P2011.pdf
Hope this helps
thanks for all that info buddy.
another update, took it for a drive today and got the light on again so got it checked asap.
The new code now reads P1018 - Intake manifold bank 2 - lower limit not reached - permenant.
I cleared the code, started the car and then re-ran the diagnostic. Code was still there but permenant had changed to 'intermittent'.
so does this mean the issue is still the motor? and how worse have i made it?
cheers
cheers
cheers
cheers
Below is a manual text on how it works.
V6 TDI intake swirl flaps.pdf
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Intake Manifold Runner Motor 2 (V275)
Check/Replace Intake Manifold Runner Motor 2 (V275)
Perform Output Test
Perform System Test using VAS 6395(A) when applicable
Check Linkage between Intake Manifold Runner Motor 2 (V275) and Intake Manifold Flap 2 Movement, Rust and when necessary use Lubricants to repair it. If the Flap is still sluggish, also lubricate the Flap Bearings.
Check/Replace Intake Manifold Flap 2
