cigarette lighter socket hot all the time. - AudiWorld Forums
Q7 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Sponsored by: Audi
LinkBack Thread Tools Search this Thread
Old 08-07-2014, 04:15 PM   #1
Default cigarette lighter socket hot all the time.
i just pick up my 2014 Q7 brand new.
find that the cigarette lighter socket on the front is hot all the time even when car is off.
anyone know this problem?
Johnsonyj is offline   Reply With Quote
Old 08-07-2014, 04:32 PM   #2
va-terps4's Avatar
Not a problem. This is how Audi does it.
va-terps4 is offline   Reply With Quote
Old 08-07-2014, 09:39 PM   #3
So I need to unplug it every time I park the car?
Old 08-08-2014, 07:56 AM   #4
When you say "hot" are you refering to the fact that it's powered on, or are you refering to the actual physical temp of the socket? Hopefully the former, as the later is definitely not normal. I thought the cig lighter socket turned off when the car goes into "standby" mode when the electronics power down around ~10minutes after you shut off the engine?
chingwodapigu is offline   Reply With Quote
Old 08-08-2014, 09:27 AM   #5
For the sake of clarity, is it the actual socket or ornamental plug that is hot? Or is it an accessory power adapter (not OEM equipment) that you have plugged in that is staying hot because it is still getting power even with the ignition off?
VAG-Fan1 is offline   Reply With Quote
Old 08-11-2014, 08:16 AM   #6
tks for the reply. what i mean hot is the power is on.
Old 08-11-2014, 08:22 AM   #7
uberwgn's Avatar
Some of the Audis have switched sockets, others don't. Our cars have both.
uberwgn is offline   Reply With Quote
Old 08-11-2014, 08:50 AM   #8
AudiWorld Expert
iconoclast's Avatar
it has current in it all the time... similar to your sockets at home. they have power but are not using it until an item is plugged in. you do not have to worry about draining the battery there is a meter built in and it cuts off power to accessories once the level dips below a certain threshold. on pre-face lift Q7 you could enable a battery meter in the MMI and if i recall correctly once it dropped down to 75% life it would shut off radio, mmi, lights etc. until you restarted the vehicle.
(a bit off topic but does anyone on here know if the battery level meter may be enabled on mmi-3g+ units? i tried a while back but did not have any success: http://forums.audiworld.com/q7-discu...mi-3g-2845903/ )
iconoclast is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
A6 C6 3.2 engine removal for timing chains uble1234 A6 / S6 (C6 Platform) Discussion 3 04-17-2016 04:57 AM
:: ECS Tuning :: NEW!! B8 S4 ECS Performance Lightweight Flywheel ECS Tuning-Audi S4 (B8 Platform) Discussion 2 03-27-2016 07:49 AM
:: ECS Tuning :: NEW!! B8 S5 3.0T ECS Performance Lightweight Flywheel ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 3 02-04-2016 09:36 AM
battery disconnect question flynavy Q7 Discussion 1 09-30-2015 06:19 PM
Trash can for an A3/S3? nate Audi A3 / S3 /RS 3 MKII 3 09-28-2015 10:27 PM
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
What's your question?
Send
