Any way to add the gear indicator next to the D or S on MFD?
In my Touareg, the Multi Function Display shows either D or S along with the gear the vehicle is in. Is there any way to enable this via VAG-COM?
Enable Gear Display (D1-D6) in DIS
a. [02 – Auto Trans]
b. [Adaptation – 10]
c. Select “Single Gear Display” from top channel drop down menu
d. Select “D on/S on” from New value drop down menu
e. Select “Do It!”
From another member: Note: May have to select “Do It!” a few times to save the change (I only had to "Do It" once for it to work).
Not sure on the Q7, but this worked on my A6 (be sure you have the latest version of the VCDS software):
e. Select “Do It!”
e. Select “Do It!”
how can i enable that button?
thanks
AudiWorld Expert
Which year is that and which region? Judging by the color of the numbers it isn't a face lift model. I have not been able to make it work on 2010+ Q7. (Specifically 2012)
