Fault - Turbo Control Circuit for Controller for Turb J724
013128 - Control Circuit for Controller for Turbocharger 1 (J724)
P3348 - 005 - Electrical Malfunction - MIL ON
Car is in limp mode. Before i start pulling things apart, can anyone help me located the fuse please?
Thanks,
Jason
Thanks,
Jason
Tried the fuse panels on either end of the dash but nothing in there...
19804/P3348/013128 - Control Circuit for Controller for Turbocharger 1 (J724): Electrical Malfunction
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fuse(s) faulty
Wiring and/or Connector(s) from/to Controller for Turbocharger 1 (J724) faulty
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Controller for Turbocharger 1 (J724)
Check/Replace Controller for Turbocharger 1 (J724)
Perform (Selective) Output Test, the Vane Positions should change visibly and audibly
Perform System Test using VAS 6395
Special Notes
When stored in the 3.0l TDI (ASB/BKS/BMK/BNG) with throttle body faults P106B/004203 and/or 17988/P1580/005504 check the throttle unit and wiring for issues that may be falsely causing the turbocharger fault.
If the wiring is ok then you are looking at a new J724.
Q7 Service and Repair Turbo.pdf
Q7 Turbocharger 1 Control Module.pdf
Possible Symptoms
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
Special Notes
Fantastic Info Smith - Thanks
I still don't see where the fuse is that controls the input voltage to the unit...
Its number one on the checklist :-)
Any ideas?
Any ideas?
4 pins or 5
I've looked that diag info you pasted - thanks again. Either i'm on a different revision or i'm looking the wrong place for the controller module.
The diag asks to test pins 1-5 but i only have 4!
I'm looking at centre of the engine nearest the windscreen. The module is slightly to the left when facing the car.
Thanks,
J
Thanks,
J
Your control Module is on your Turbo. Below is a overview (#19 on the page)
I do not have diagram of the plug. I do know you need a program to plug into the turbo to check your system. VAS 6395/1 if you do not have this you are stuck to go to the dealer.
Q7 Turbocharger Overview.pdf
Pic of a J724
J724?Home.pdf
This is what the VAS looks like which you need to reprogram.
Audi V6 TDI 2.7 & 3.0 Turbo Controller
Pic of a J724
J724?Home.pdf
Q7 fuse box engine.pdf
Q7 Fuses In the Left E-Box Plenu.pdf
RoadTrippin
06-09-2003 05:31 AM
