help 07 Q7 4.2 EPC and other lights on
#11
I wouldn't think so. Had you not gotten fuel codes, I wouldn't have thought that. But with electronics in newer vehicles, you never know. Usually when you get an epc light, there's a short somewhere, a low battery, a loose connector, or the part actually failed. If all else fails, take it to an audi dealer or indie mechanic with all the factory diagnostics.
#12
you need to put an intelligent charger .
Q7 NEED A LOT OF ELECTRICITY TO RIDE ON CITY,EVERY TIME WHEN YOU MAKE A STOP OR PUSH ON ACCELERATION A LOT OF ENERGY COME FROM THE BATTERY TO GET ON YOUR ENGINE TO PUT MORE POWER. I KNOW THE GENERATOR GIVE ALSO POWER, BUT NOT ENOUGHT.
ON CITY THE RPM IS RUNNING ABOUT 2000 AT 3000 RPM IN A SHORT TIME. IN YOUR CASE I THINK THE BEST RESULT ,IF YOU DON'T WHANT TO FIX A INTELLIGENT CHARGER.
YOU SHOULD GO ON THE HY-WAY FOR A COUPLE OF HOUR. IT'S YOUR CHOICE , SPEND MONEY AND TIME ON GAZ OR CONNECT YOUR Q7 AT HOME IN A SECOND.
#13
A large percentage of your codes are centered around Fuel Pressure or are a result of the engine not running properly.
Do you hear the fuel pump run when you turn the car on but not start it? Pump will always prime on start up, so you should hear it run for a few seconds.
Inspect the fuel pressure sensor wiring.
OrlandoDave
A4 (B7 Platform) Discussion
12-26-2023 01:19 AM
JiBBeL
15
04-13-2018 08:26 AM
Reggie
RS4 (B7 Platform) Discussion
06-10-2010 09:25 AM
skapan
06-12-2008 05:34 PM
