Help deciphering VAG VCDS report. Fault with adaptive air suspension.
#11
Hi Guys, so yesterday i was out in the car and i'm now getting amber and green flashing suspension lights at the same time. Not had a chance to run another diagnostic, will do 1 later and post. Does this make things any clearer?
Thanks
Thanks
#15
You need to know that the compressor is working alright by testing it and then try leaving the car parked for a few days and see if any corner droops to be lower that the others. If it does, try leaving it in jacking mode and see if it droops again.
You are not getting errors from the level sensors but they can still be sending strange values which can cause all sorts of other faults to appear.
If you have the full version of VCDS try running the adaption process. You will have to clear faults first then follow the process making sure the drivers' door is closed and have the laptop lead through the drivers window with you standing outside.
trapp
11
01-18-2018 05:43 AM
Druff
Q7 MK 1 Discussion
01-28-2016 11:33 PM
