Help!!! Upgrading Q7 steering wheels
I upgrade my Q7 3.6 2009, but when i remove the old one, i see some problem. All the jack and cable is fix except this. The original jack of airbag have 6 plugs, but the new airbag just have 4 plugs- See the picture below. Any one help or provide me the suggestion. Thanks so much!
The original 2009 airbag
The new airbag
The new airbag
you are probably SOL...
I swapped my wheel for one with a paddle shift, but the trick is you have to use the same year. The computer interface on these is very complex and I doubt you could do anything except a straight year for year swap to get ANYTHING to work properly.
good luck if you pursue this any further as you will need lots of luck and skill to make it work safely.
uh huh...
Not true at all, as long as you have access to a VAG-Com cable, you can 'reprogram' the ecu to accept any steering wheel to any model year Q7. That said, to the OP's question, i'm pretty sure the old airbag will not work or fit the new steering wheel with the round airbag. What style steering wheel are you using HDAUTO?
like I said SOL without a L O T of fiddling...just sayin...
Hduto; check out this thread.
https://www.audiworld.com/forums/q7-...ed-q7-2884101/
FlyNavy; the Vag-com is necessary to engage paddle shifters on a new wheel to a car that didn't previously have paddles. As for the harness connections, i went from a heated wheel and rectangular airbag to a flat bottom with the newer round airbag without heated. I'm 99% sure it was a direct swap/plug and play without a lot of fiddling around although i wasn't involved in the install. maybe someone else on AW can chime in here?
why yes it is...
It is a can of worms at best to change these things 100% successfully. Now if you know a "secret" option on the vag to enable my heated paddle shifter wheel on my 2012 prestige then I an ALL EARS!
I used VAG to switch my 2012 to a paddle whell shifter it worked flawlessly, the wheel was from the same year. Now as to the heat option on my new wheel there is no way to activate it if your car was not originally equipped with a heated wheel. I tried ALL the various options and even spent money on an expert who switched the control module in a vain attempt to make the new heated wheel work and viola NO WORKIE!
