Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
How do I replace the headlight bulbs?
Old 12-31-2009, 02:50 PM
  #11
floincali's Avatar
I just did this the other night and now I am getting a code saying my headlight range cotrol is defective. Any ideas as to getting this code removed? The lights work great btw. All help will be appreciated.
Anthony
Old 01-03-2010, 09:27 AM
  #12
atsea150's Avatar
I seem to be having same issue - cant disconnect the electrical harness - any help out there; thanks and happy new year.
Old 01-03-2010, 11:18 AM
  #13
floincali's Avatar
All you have to do with the harness is push down on the end of it and pull at the same time. It feels like you aren't moving the piece, but you are. I had a hard time as it was cod outside when I tried this. But it finally came out. B careful when pulling out the headlight as the piece of the grill tends to catch on the headlight. A lot of wiggling is involved with putting the headlight back in as well. Good luck and hopefully you don't get the headlight error I got when I did the bulb swap. Just purchased a Vag Com so hopefully I can remove the code.
Anthony
Old 01-31-2010, 09:53 AM
  #14
Bigman's Avatar
Default Thanks for the saving, it works perfect for me.
Many Thanks to mksap11, saving me a lot of headache. I unplugged the rear electric power cord then unhooked keylock and press down the front lock and push the headlight kit forward. Then pull out the lights and replace both. It was tricky to push back the light, just make sure keep the pointer upward to insert back to the socket.
Good luck guys.!!!!
Old 09-21-2010, 02:06 PM
  #15
Halvecto's Avatar
Default Something so difficult becomes so simple!
mksap11,
You are the man! I cannot believe I actually took my car in twice for headlight replacement. Both times I was left scratching my head as to how to get that darn light out and new one in. After seeing your pictures and reading the explanation it took me all of about 10 minutes to replace both (yep, I had both lights go out within a day of each other). This is the third light for me on the driver side.
Heads up to others: unplugging the the electrical harness is very easy with the aid of a screwdriver to push the connector piece. Also, when putting the assembly back in, take a look inside the opening from the front as you insert it back in and align the slide with the T mold and it will self align as you push it in.
Old 09-21-2010, 04:54 PM
  #16
justinator's Avatar
Default Does this procedure work for Q's with adaptive headlamps?
Or are all Q7's equipped with the adaptive feature?
Old 09-21-2010, 04:59 PM
  #17
adriangroom's Avatar
No, adaptive feature is specific to certain packages.
Old 09-24-2010, 08:35 PM
  #18
zerophat's Avatar
nice, the DRL was out, and replaced it in 10 minutes.
Old 09-25-2010, 09:34 AM
  #19
ballfire's Avatar
So is procedure same for Q7's equipped with the adaptive headlights?
Where are better stores to purchase the xenon lamps?
Is it worthwhile purchasing the VAG-COM? Does it allow you to do your own oil changes?
Old 06-06-2011, 11:07 AM
  #20
hrance1's Avatar
Originally Posted by Railflyer
You are correct, just pull up that tab that is in the inner part of the head;lamp housing and then push down the tab that is on the outside of the assembly then push out the front of the car. Those screws hold the lamp assembly mount. The headlamp just slides into that mount.
hi there, i am new to this, i have a 2009 Q7 S line with Halogen headlights. they are 55w bulbs, can i upgrade them to brighter bulbs do you know ? thx.
Quick Reply: How do I replace the headlight bulbs?
