Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
How to lubricate panoramic sunroof
Old 11-04-2015, 01:34 PM
Nick_M's Avatar
Default How to lubricate panoramic sunroof
Although I have the leaking sunroof issue, this post isn't about that
My sunroof opened and closed ok but I noticed that when it was closing about 3/4 way, it would start vibrating and seem to struggle a little, but it still ended up closing ok. So, I thought maybe I should lubricate it. I read a few suggestsions elsewhere to use a white lithium grease spray. I did that and sprayed in the channesl where it appears there is like a long drive screw on both sides. To my surprise, this appeared to make it worse. It now seems to vibrate and struggle more when closing and I can even here it make a little noise when it is opening that wasn't there before I sprayed in the lubricant. Baffled on how this made it worse. Any ideas? Did I use the wrong lubricant? Is there a specific method documented by Audi on how to lubricate it appropriately (maybe should have asked that before doing this)?
Old 11-04-2015, 02:10 PM
Nick_M's Avatar
Just found the below procedure in a TSB when searching on this topic in another forum.
Q5 / Audi Q7:
1. Lubricate the seals with special lubricating paste G 052 141 A2.
Tip: No parts have to be removed. It is only necessary to completely open the
sunroof panel.
2. Lubricate the mechanism components with lubricating paste G 055 751 A2
Old 11-05-2015, 08:21 AM
markray's Avatar
Exact thread I followed/used
Old 11-07-2015, 10:51 AM
M3 Ninja's Avatar
great post.
knepster1
05-02-2008 02:44 PM
MMskiAudi
NY / NJ / CT Discussion
04-06-2008 06:57 PM
Bob W.
RS4 (B7 Platform) Discussion
40
11-04-2006 12:01 PM
tornadoJatt
13
04-29-2006 12:27 PM
the red pill
08-09-2002 06:03 PM
Quick Reply: How to lubricate panoramic sunroof
