Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Transmission Fluid 2010 TDI
Old 05-28-2014, 12:38 PM
Polskidebesciak's Avatar
Default Transmission Fluid 2010 TDI
I know that Audi says its lifetime, but to me thats just bs. Anybody know a good diy guide.
Old 05-28-2014, 05:02 PM
Prospeeder's Avatar
Every 40k-60k miles is a good interval. Just drain, remove the bolts holding the pan, remove the filter, and replace the cleaned pan. Then Remove the larger fill plug, and use something to fill the trans.
I use an electric fuel pump I rigged up to pump fluid into the transmissions. I also bought another fill plug, drilled a hole in it, and welded a 3/8 nipple onto it and use an oring on it and pump fluid in, probably 6 quarts, and then start the engine, and remove the hose, let the excess drain off, (or continue adding if nothing comes out) and replace the plug. Use a rad temp gun and when the pans about 70F remove the fill plug again and drain any more excess and its perfect. Dont allow the trans fluid to get higher than 90F or you will underfill the trans.
Old 06-01-2014, 09:24 PM
Anybody used this kit? http://www.blauparts.com/proddetail.asp?prod=F2A1020-A
or should I go with something else?
Old 06-02-2014, 04:13 AM
DUTCH VanAtlanta's Avatar
Temp range for checking fill level is 35°C-45°C (95°F-113°F) or 50°C (122°F) for hot countries. 70°F will result in an over fill.
Robert Schirmer
66
03-16-2020 02:46 AM
SmgCisHERE
07-06-2016 09:00 AM
Mr Paul [T-28]
05-30-2007 02:49 PM
Vodka G
04-08-2007 06:30 PM
2000TTC
06-19-2003 12:38 AM
Quick Reply: Transmission Fluid 2010 TDI
