Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
license plate bracket
Old 11-04-2012, 09:24 AM
LOP
LOP's Avatar
Default license plate bracket
In search for an alternative front license plate mount, I found this one for a fiat 500...you have to specify for the abarth 500 which also fits other cars. It was the only one I found that was long enough to stick out far enough and reach a solid mounting point.
Read my review on the link to get a description of how it was mounted. I will try and post pics later, but I mounted it using the screw points in the front of the lower radiator support into some L-brackets and then mounting the plate holder to the top of the brackets.
On my s-line prestige I snaked it through lower grill opening of the bottom fascia.
Amazon Amazon
Old 11-05-2012, 08:23 AM
arp2nr's Avatar
I used a “no hole license plate brackets” that goes into the front tow hook. To avoid the park sensor I used the left offset mount. And finally to get it to go farther away from the bumper I used a 1” bushing.
http://www.gominigo.com/NHLPB-main.html
http://www.amazon.com/Cravenspeed-Pl...e+mounting+kit
Old 11-05-2012, 03:33 PM
LOP
LOP's Avatar
no front tow hook on my Q7
I use the bracket you mention on wife's mini cooper s JCW.
Old 11-09-2012, 04:06 AM
arp2nr's Avatar
here are pics of the plate attachment to the tow hook
Old 11-20-2012, 11:45 AM
NeedsWork's Avatar
[QUOTE=LOP;24368721]no front tow hook on my Q7QUOTE]
Ditto - no tow hook option that will work for us Q7 guys.
Old 01-17-2013, 07:33 PM
LOP
LOP's Avatar
Pics finally uploaded to post #1
AND YES, my Q7 is embarrasingly dirty...finally getting the rain we need, she gets a bath manana.
Old 01-22-2013, 01:44 PM
NeedsWork's Avatar
Any chance we can see a further back pic of the plate actually on the front of the Q? Also maybe more details on the 'modified L-brackets' you used? THANKS!
PS - Dirty photos are better than no photos!
Old 01-25-2013, 07:50 AM
LOP
LOP's Avatar
Pics updated in post #1
I made the brackets out of stainless steel, but they are just L-brackets and I used nylon spacers to elevate the plate mount a bit...but I mounted the brackets to existing oem mount points on the radiator support. This way there was no drilling and no weak points created.
You will understand better once you look at your Q7 in that area. Those pics do not do it justice.
BTW, you can flip the platypus plate mount upside down if you want your plate to mount higher...I didn't so I didn't risk blocking any air flow and I really did not want the plate to stand out any more than it already does.
bballfreak
9
04-14-2019 06:59 PM
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
schalliol
A6 (C7 Platform) Discussion
13
10-03-2015 06:56 AM
dymio2
TT (Mk2) Discussion
09-24-2015 07:44 AM
Quick Reply: license plate bracket
