Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Minimum rotor thickness
Old 08-20-2010, 08:10 PM
pchansen's Avatar
Default Minimum rotor thickness
Does anyone know that the minimum rotor (disk) thickness is on my 2007 Q? I've just received Hawk LTS Pads and sensors and my plan is to just have the lip on the disks machined down and re-use the rotors if possible. If necessary, I'll order new rotors. Also, how many miles do you have left, once the pad warning light comes on?
Old 08-21-2010, 01:40 AM
SteelWarHorse3.0TDi's Avatar
The warning light is only for pad thickness and has nothing to do with rotors. When the warning light comes on the amount of driving you have before changing the pads depends on how you drive. I wouldn't go more than a 1000 km and that's pushing it. Strict dealships will replace the pad immediately the light goes on./
There seems to be some dicrepencey between the EU and the US on rotors. As I undertand it US dealerships are "required" to change the rotors when the pads are changed, which seems insane to me as if more than doubles the cost. Here in the EU I have change the pads twice on one Q7 and never changed the rotors. The do have a lip and I assume the third pad change will also require a rotor change.
Old 08-21-2010, 06:03 AM
Jusforfun's Avatar
Why bother machining the lips?
Wear is a mere 1mm per side total reduction of 2mm to replacement
Disc/Rotor thickness 34mm
Minimum Rotor thickness 32mm
Its the same spec accross all models or rims size
Old 08-21-2010, 10:13 AM
pchansen's Avatar
Well, I'm right at the minimum thickness now. I bought the car with 36000 miles on the clock and I'm at 51000 now. I don't know if the car is on it's second set of rotors now but in any case I'm replacing the rotors with Frozen Rotors.
Old 08-23-2010, 11:30 AM
Standards for miniumu rotor thickness appear to be ver dependent on your country... :-/
Here in portugal our 07/01 Q7 had its first rotor replace ment at 150,000 km - went through four sets of pads. Note that this was an Audi dealership and associated Audi shop.
None of this "must replace rotors and pads at the same time" crap.
None of this "oh noes! The rotors have worn by 2 mm - replace them noaw!".
I think both the pads/rotor and the 2mm wear limit is trumped up rubbish designed to screw over the uninformed by turning a 450 Euro pad replacement into a 1200 Euro pad + rotor replacement.
But that's just me.
Old 08-25-2010, 04:05 PM
Jusforfun's Avatar
Its not just you... its me too. They are soft material to match pad wear but mine looked perfect at first pad replacement (despite wear) so they stayed. I will certainly monitor them really carefully. Slightest sign of a crack or pedal hop they're out of there but for now still probably the best rotors I have ever had!
DrivingFool
RS4 (B7 Platform) Discussion
11
04-12-2011 09:27 AM
siki
12-05-2005 11:52 AM
Dr.Aronis
RS 6 Discussion (C5)
22
10-13-2005 11:32 PM
Karpedmman
03-19-2004 12:31 PM
RogerB
Audi 100 / A6 (C4 Platform)
06-06-2002 05:19 AM
Quick Reply: Minimum rotor thickness
