Misfire Code Help !
Misfire Code Help !
My 09 Q7 V-6 is showing 2 codes, one for intermittent misfire, and the other shows misfire cylinder 6, so I pulled the old swap the coil packs trick. I swapped 5 to 6 and 6 to 5 and cleared the code. Car ran nice no miss, couple of days later, down on power, CEL comes back on and its showing # 6 misfire again? Any ideas, usually this rules out that #6 coil pack being good or bad. Could that plug be fouling ? Why then ould it run better when clearing the code ??
thanks for the codes.
P0306 is your hard code which you are on the right track in swapping the coil packs, but you forgot to swap the plugs too, or replace them. I prefer to replace #6 plug and then clear codes and wait.
Next step if it does not swap then you have a injector problem/ fuel pressure problem.
below injector test.
Q7 Fuel Injectors, Checking P0306.pdf
Hibiscus Red S4
06-04-2007 05:02 PM
