Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
2013 Q7 TDI with towing package
Old 01-25-2014, 03:42 PM
calgary-Q7's Avatar
Default 2013 Q7 TDI with towing package
Hi, I am new to the forum and have a question about the OEM tow package. I noticed on some Q7's that there is a blanking plate where the 7 pin connector should be. I obviously need an adapter of some sort so that I can plug the trailer wire harness in but my question is: Does the vehicle need to be coded to activate the trailer plug wire or will it work with the adapter ?
Thanks
Old 01-25-2014, 04:12 PM
Ultimate Keyboard Warrior
Force-1's Avatar
Plug-N-Play.
Amazon.com: Genuine OEM Audi Q7 Seven Pin Trailer Harness Connector (2007+): Automotive Amazon.com: Genuine OEM Audi Q7 Seven Pin Trailer Harness Connector (2007+): Automotive
Old 01-26-2014, 03:09 AM
DUTCH VanAtlanta's Avatar
This is what I used. It's plug and play, too; and for considerably less money.
http://www.etrailer.com/Wiring/Pollak/PK11893.html
If you have the factory tow package, no coding is necessary; although, if you want electric trailer brakes, you'll need to find the plug up behind the dash to connect the controller.
Old 01-27-2014, 06:43 PM
J. Patterson's Avatar
Same here. this one fits and works perfectly.
mateostyle
Q7 MK 1 Discussion
11-10-2018 11:07 AM
cwdonahue
Q5/SQ5 MKI (8R) Discussion
03-26-2012 08:36 PM
KiddyBus
Q7 MK 1 Discussion
01-16-2007 05:59 PM
Randolph
02-09-2006 06:16 AM
Audilard
12-13-2004 06:36 AM
Quick Reply: 2013 Q7 TDI with towing package
