No hot air blowing in cabin
Havent looked at car yet, wife reports there is no heated air blowing into the cabin. Blown fuse will be first i guess. Anyone had this happen? 08 4.2
yes, got heat, i dont know what the wife was talking about. I need to do the hvac basic settings. I will run another scan, there are more problems. airbag n199 is making the air bag light go on. passenger touch sensor, and the saga continues with this constant issue car
It will take time, but when done I do know the Q7 will ride outstanding on the road again.
What I have found about N199.
When "Short to positive" or "Short to ground" is found, DO NOT CLEAR THE DTC. This can cause the airbag to deploy. See repair manual for more information.
Check Wiring/Connectors from/to Side Airbag Igniter, Front Driver Side (N199)
Check Side Airbag Igniter, Front Driver Side (N199) faulty
Check Measuring Value Blocks (MVB)
Air bags to me is very costly(cause you can deploy the bag) by a DIY tech, I recommend for a professional.
OC02ALLROAD
Audi allroad
11-06-2008 07:22 PM
9490s33990
03-02-2005 02:42 PM
