P0456-001
P0456-001
CEL came up on my 2007 Audi Q7 and it says I have a very small leak detected. Was told it was my N80 valve which I replaced and had code cleared. Code came back again, any ideas what else it could be? Vacuum leak? Let me know if anyone has any ideas, thanks guys!!
need to check Evaporative Emission (EVAP) System lines for a small crack. leaking/faulty
This is hard, but maybe you will get lucky. Now to check the system a smoker machine will find this leak. Fill the lines with smoke and look at the whole system for the leak.
also it will take sometimes 3 or 4 days for the computer to clear the code, needs to run its cycle.
Could also just be the fuel filler cap. I had to replace the cap on my 3.6 to cure an EVAP related CEL (don't remember the OBD P-code). The 4.2 hasn't had the issue (yet) but the seal on the fill cap is getting hard and cracked like the 3.6's was when it was throwing the CEL.
