Last edit by: IB Advertising
- Audi Q5/Q7 How to Jump Start Car<br>Step by step instructions for do-it-yourself repairs.
CR: Please Help!!! TDI Q7 won't start!
#11
#12
Yes, my car has keyless entry and engine start.
#14
Ok, Here is an update...
Finally got my Carista scanner and app and here are the results:
ECU info obtained with Carista 260099 for iOS:
CAN network gateway
Part #: 4L0910468A
Component: J533__Gateway
Coding: F7FBFE7770120200 (hex)
[No fault codes]
Trailer
Part #: 4E0907383E
Component: Anhaenger
Coding: 0100000000000000 (hex)
[No fault codes]
Battery regulator
Part #: 4L0910181A
Component: J0644 BEM
Coding: [none]
[No fault codes]
Parking sensors
Part #: 4F0910283H
Component: Parkhilfe 8-Kan
Coding: 231046 (decimal)
[No fault codes]
Ignition authorization
Part #: 4F0910852
Component: FBSAUDIC6 ELV
Coding: 135 (decimal)
[No fault codes]
Central electronics
Part #: 4F0910279K
Component: ILM Fahrer
Coding: 12101 (decimal)
[No fault codes]
Central electronics 2
Part #: 4F0910280
Component: ILM Beifahrer
Coding: 11101 (decimal)
[No fault codes]
Body/convenience system
Part #: 4L0910289F
Component: Komfortgeraet
Coding: 7350521 (decimal)
[No fault codes]
Part #: 4L0910290
Component: ILM HINTEN 2
Coding: 1 (decimal)
[No fault codes]
Auxiliary heater
Part #: 4L0910105
Component: Heizgeraet
Coding: 1 (decimal)
[No fault codes]
Heater & air conditioning
Part #: 4L0910043
Component: KLIMABETAETIGUNG
Coding: 131094 (decimal)
[No fault codes]
Rear heater & A/C
Part #: 4L0910158
Coding: 6 (decimal)
[No fault codes]
Steering wheel
Part #: 4F0910549A
Component: J0527
Coding: 2142 (decimal)
[No fault codes]
Driver's seat
Part #: 4F0910760
Component: Sitzmemory FS
Coding: 82954 (decimal)
[No fault codes]
Driver's door
Part #: 4L0910793B
Component: TSG FA
Coding: 19147 (decimal)
[No fault codes]
Front passenger's door
Part #: 4L0910793B
Component: TSG BF
[No fault codes]
Rear left door
Part #: 4L0910795B
Component: TSG HL
Coding: 18442 (decimal)
Fault codes:
02126 Central Locking Button Exterior Door Handle
Rear right door
Part #: 4L0910795B
Component: TSG HR
[No fault codes]
Trunk
Part #: 4L0910945
Component: ValeoHeckdeckel
Coding: [none]
[No fault codes]
Back-up camera
Part #: 4L0910441A
Component: J772__Rearview
Coding: 1030101 (decimal)
Fault codes:
00778 Steering Angle Sensor (G85)
Instrument cluster
Part #: 4F0910930C
Component: KOMBIINSTR. M73
Coding: 3585158 (decimal)
[No fault codes]
Airbags
Part #: 4L0910655D
Component: 71 AIRBAG AUDI8R
Coding: 14129 (decimal)
[No fault codes]
ABS
Part #: 4L0910517B
Component: ESP ALLR
Coding: 99457 (decimal)
Fault codes:
01826 Sensor for Steering Angle (G85), Voltage Supply Terminal 30
Transmission
Part #: 09D927750FS
Component: AL 750 6A
Coding: 504 (decimal)
[No fault codes]
Steering angle
[failed to connect]
Headlight aiming
Part #: 8P0907357F
Component: Dynamische LWR
Coding: 7 (decimal)
[No fault codes]
Engine
Part #: 4L0910401T
Component: 3.0L V6TDI G040
Coding: 11779 (decimal)
[No fault codes]
Adaptive cruise control
[failed to connect]
Lane-maintain system
[failed to connect]
Lane-change system
[failed to connect]
Infotainment display
Part #: 4L0910731L
Component: Interfacebox
Coding: 2004 (decimal)
[No fault codes]
Media player
Part #: 4L0910110A
Component: MP3-Changer
Coding: [none]
[No fault codes]
Media player
Part #: 4E0035785B
Component: SG ext.Player
Coding: [none]
[No fault codes]
Radio
Part #: 4E0910541Q
Component: TUNER EU/US/RDW
Coding: 1 (decimal)
[No fault codes]
Telephone
Part #: 4E0910336K
Component: Handyvorb2
Coding: 10990 (decimal)
[No fault codes]
Sound system
Part #: 4L0910223G
Component: DSP-High AU716
Coding: 12 (decimal)
[No fault codes]
Engine
[failed to connect]
Obtained with Carista 260099 for iOS.
I don't see anything there that could be causing the car not to crank, is there??
Once again, thanks a lot for your input!
CAN network gateway
Part #: 4L0910468A
[No fault codes]
Trailer
Part #: 4E0907383E
[No fault codes]
Battery regulator
Part #: 4L0910181A
Coding: [none]
[No fault codes]
Parking sensors
Part #: 4F0910283H
[No fault codes]
Part #: 4F0910852
[No fault codes]
Central electronics
Part #: 4F0910279K
[No fault codes]
Part #: 4F0910280
[No fault codes]
Part #: 4L0910289F
[No fault codes]
Part #: 4L0910290
Coding: 1 (decimal)
[No fault codes]
Auxiliary heater
Part #: 4L0910105
Coding: 1 (decimal)
[No fault codes]
Part #: 4L0910043
[No fault codes]
Rear heater & A/C
Part #: 4L0910158
Coding: 6 (decimal)
[No fault codes]
Steering wheel
Part #: 4F0910549A
Component: J0527
[No fault codes]
Driver's seat
Part #: 4F0910760
[No fault codes]
Driver's door
Part #: 4L0910793B
Component: TSG FA
[No fault codes]
Part #: 4L0910793B
Component: TSG BF
[No fault codes]
Rear left door
Part #: 4L0910795B
Component: TSG HL
Fault codes:
Rear right door
Part #: 4L0910795B
Component: TSG HR
[No fault codes]
Trunk
Part #: 4L0910945
Coding: [none]
[No fault codes]
Back-up camera
Part #: 4L0910441A
Fault codes:
Instrument cluster
Part #: 4F0910930C
[No fault codes]
Airbags
Part #: 4L0910655D
[No fault codes]
ABS
Part #: 4L0910517B
Component: ESP ALLR
Fault codes:
Transmission
Part #: 09D927750FS
[No fault codes]
Steering angle
[failed to connect]
Headlight aiming
Part #: 8P0907357F
Coding: 7 (decimal)
[No fault codes]
Engine
Part #: 4L0910401T
[No fault codes]
[failed to connect]
[failed to connect]
Lane-change system
[failed to connect]
Part #: 4L0910731L
[No fault codes]
Media player
Part #: 4L0910110A
Coding: [none]
[No fault codes]
Media player
Part #: 4E0035785B
Coding: [none]
[No fault codes]
Radio
Part #: 4E0910541Q
Coding: 1 (decimal)
[No fault codes]
Telephone
Part #: 4E0910336K
[No fault codes]
Sound system
Part #: 4L0910223G
[No fault codes]
Engine
[failed to connect]
#16
#17
These are signs that not enough fuel is getting through to the engine to provide the required power from combustion. This indicates a partial blockage of the fuel system. The most likely place for a blockage is at the main fuel filter, situated on the fuel line between the fuel tank and the engine. The fuel filter is a bowl containing a disposable cartridge made of corrugated paper designed to remove dirt particles greater than 10 micron in diameter. Some filters will also remove water which is collected in a trap and must be drained at regular intervals.
The quickest way to resolve the problem is to get a sample of the fuel from the fuel tank before the filter in a clean glass jar and look at it in a good light. If the fuel is clear and bright then changing the fuel filter should fix the problem. If the fuel is hazy or has particles floating in it, it will block filters and it should be replaced before the filter is changed.
#18
COLD START SOLVED - Hi there, i had the same problem with cold starting where first thing in the morning it would take a good 10 - 15 seconds of cranking before it would fire. There would be a hell of a lot of smoke each time which was a little embarrassing. Replaced the injectors and glow plugs with no change. I was then about to change the glow plug relay (as there turned out to be no power to the glow plugs when the key was switched each time) when disaster struck. I was returning from a long distance trip when the car 'overheated' and went into limp mode. Once i returned home, i went through and found that the engine hadn't actually overheated and that the temp sensor on the engine side (not radiator - yes it has two) was sending an incorrect signal. Once replaced I found that the car started immediately each morning and that the gauge now reads correctly. in fact the whole car seems to drive incredibly well after that with no low - mid speed flat spot - slow gear change that it use to have.
What was happening was the sendor was telling the vehicle that it was between 30 - 50 degrees each time, meaning that the computer wouldn't fire the glow plugs, as it was warm enough to fire the engine. anything below 30 degrees and the relay is activated to ignite the glow plugs
Easy to change, it sits behind (and below ) the top left intake pipe and is removed by a small clip. Cost me $50 and 15 mins time with most of that digging behind the engine to find it.
Hope that helps if you are having any of these issues
craylarisa@yahoo.ro (12-18-2022)
#19
Grey
#20
God Bless you sir! This resolved my issue!
Raydon (05-21-2020)
