Q7 2007 3.0 TDI Outside temperature problem
Hi,
I have a problem with outside temp.
I replaced outside temp. sensor, but problem still exist.
Any sugestions welcome.
Thanks in advance
Please see the youtube video
Thanks in advance
I guess the 13°C was about right to start off with for last night as we had about the same in England.
Do all the other instruments work correctly?
I would suspect a CPU fault in the instrument cluster assuming that is where the thermistor feed goes to?
Address 08: Auto HVAC (4L0 910 043 )
02:05:22 Group 018
28.0°C Temperature
27.0°C Temperature
26.0°C Temperature
26.0°C Temperature
02:05:22 Group 019
22.0°C Temperature
-4.0°C Temperature
18.0°C Temperature
Not Occup.
02:05:22 Group 020
23.0°C Temperature
2880 /min RPM
38.0°C Temperature
OFF
02:05:22 Group 018
28.0°C Temperature
27.0°C Temperature
26.0°C Temperature
26.0°C Temperature
02:05:22 Group 019
22.0°C Temperature
-4.0°C Temperature
18.0°C Temperature
Not Occup.
02:05:22 Group 020
23.0°C Temperature
2880 /min RPM
38.0°C Temperature
OFF
1K0 907 543 A thru G
Older Q7's will have the original 'A' version. This has been superseded and now if you go to Audi and your car had an 'A' from factroy they will sell you the 'G' which is the latest version (the letter at the end is just a revision code). So, the letter at the end should make no difference if you are buying a used one, just get any one you can and should work fine. The 1K0 907 543 is the important part.
Hope that helps!
Hello
I just bought a Q7 2008 4.2 and have exactly the same issue.
Is there an easy way to locate the G89 sensor so I can confirm same diagnostic and change it?
or is this dealership kind of thing?
pretty handy but never touch a car except tires and oil change
thank you
thank you
Joe C
09-03-2001 07:58 PM
