Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Q7 3.0T s line rattle when start up.
Old 08-07-2013, 10:39 PM
  #11
mikemdd's Avatar
My 2002 A6 4.2 has done this since about 10k miles. Now has around 90k with no problems. I noted it at every service for the record but have had no issues. I agree that it sounds really bad.
Old 08-08-2013, 04:36 AM
  #12
flexaholic's Avatar
I will try and get it on video this weekend!
Old 07-02-2015, 03:24 AM
  #13
adamg802's Avatar
Default Same Issue
Originally Posted by flexaholic
I recently purchased a 2011 q7 3.0T s line and love the SUV but am embarrassed to start it... Most times i start it, especially when cold.. there is a rattle in the motor that lasts a few seconds and seems to be on the drivers side.. Ive ruled out any external noises like heat shields. I had it to the dealer and they say its normal, they read me a bulletin from Audi saying it takes time to get oil up to the heads or valves,i forget the exact term they used as i was very disappointed.. and it may rattle for a few seconds. this just doesn't seem acceptable from a vehicle of this caliber!! Has anyone encountered this in the Q7 3.0T and did you have any solutions?? Thanks
Absolutely everyone will make this sound if not already doing so, sorry for a late reply was just browsing the forum. I have a 2011 Q7 3.0 Supercharged and has made the sound since 10k. I also have a 2010 Stage 2+ S4 same sound, multiple friends of mine also have S4's and there's do it as well. Granted the S4's oil delivery is better so I only hear it from time to time and if the cars been parked for a few days.. Hope it helps mate
Old 07-02-2015, 07:22 AM
  #14
RAudi Driver's Avatar
Sounds like an electronic cutoff switch is in order.
Old 07-02-2015, 07:48 PM
  #15
davidbod's Avatar
Mini Coopers have this same issue. Its the timing chain tensioner / guides. Not sure about the Audis, but in the Minis its very sensitive to oil level. If its at all low it gets worse. As long as it goes away quickly after engine start its normal.
Old 07-03-2015, 04:10 AM
  #16
AudiWorld Expert
iconoclast's Avatar
Originally Posted by arkbbq
The TSB provides more questions than answers. It does not reference a particular engine - so this is supposed to apply to all Audi engines?? Seems unlikely.
3.6, 4.2 and at the end of 2008 TDI was available in 2009+ models.
Old 07-03-2015, 05:11 AM
  #17
cuatrokoop's Avatar
My 3.6 rattles at start-up. It's oil related, lasts a few seconds while pressure builds. It's either a lifter or two or the oil-pressure operated tensioner. On my '98 A6 (112k miles) I just had to replace the driver side cam chain tensioner and three intake lifters on #4 cylinder.
Old 09-01-2015, 02:43 AM
  #18
aghaddad's Avatar
Default Rattle on start up
Hi I am new this. I have 2010 Sline with same problem. It has just gone into Audi Service today. I will let you know what they tell me.
I am a mechanic myself, but have never touched one of these.
Regards
Andrew
Old 09-03-2015, 06:20 PM
  #19
aghaddad's Avatar
Regards
Andrew
Just been told by Audi Service, 99% sure that it is the Timing chain tensioner that is the problem. $9k to fix.......
Old 09-04-2015, 02:15 AM
  #20
cuatrokoop's Avatar
Evidently the engine has to come out? Seems quite unreasonable, parts are probably only a few hundred dollars.
Even if parts were $1k, that would mean they need to spend 80hrs doing the work at a rate of $100/hr. Did they give you an estimate with the break-down?
Quick Reply: Q7 3.0T s line rattle when start up.
