Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Q7 drain pipes clogged
Old 11-29-2015, 12:07 PM
MelsQ7's Avatar
Default Q7 drain pipes clogged
Audi dealer had my 2009 4.2 prestige in for a collision repair and when I got it back I took it to the car wash, and water, atleast 2cups or more, leaked into the car on passenger side floor mats... They said it's a typical issue for the Q7 due to clogged drain pipes running from the sunroof.. Is it easy to clean or another costly service?? How is this not a recall!!??
Old 11-29-2015, 05:18 PM
cuatrokoop's Avatar
Common issue, for some reason not a recall. It was around $300 to fix the front right drain tube on my 4.2. My 3.6 so far has been fine (or previously fixed), knock on wood...
Old 11-30-2015, 03:46 PM
MelsQ7's Avatar
Ok I'm seeing threads on this issue and repairs varying from $300 to $800.
Drano less than $10 right? Big no no I guess.
Old 12-01-2015, 06:57 AM
Buckwheat2088's Avatar
I wouldn't put drano down the drains unless you want drano to leak into the car. The clog is most likely at the very end of the drain and it's possible to clear the clog yourself by removing the wheel well lining behind the tire, locating the drain, and reaching in with a finger or 2 to pull out the debris. It's also possible to run some sort of thin cable down from the top of the drain and push everything out.
There are detailed instructions/photos on how to do this somewhere on the forum. A quick search might yield the info I'm talking about.
Old 12-03-2015, 05:11 AM
bmwrt's Avatar
I had the Dealer retrofit the front drains and I did the rear myself before the right rear fails and damaged the Amp which cost close to 1000K.
charliehereforyou
Q7 MK 1 Discussion
13
02-13-2021 06:09 AM
Q7Ash
Q7 MK 1 Discussion
09-05-2019 09:20 AM
737flyer
Q7 MK 1 Discussion
01-08-2019 11:55 PM
HaveBullDogWillTravel
Other (Non-Audi) Autos Discussion
12
03-31-2010 10:25 AM
Q7Miami2007
Q7 MK 1 Discussion
03-12-2007 04:44 PM
Quick Reply: Q7 drain pipes clogged
