Q7 Flex pipe broke /replaced error P0420/P0430 coming..
Hi guys
I own a 2009 Audi Q7 3.6L. My flex pipes after the catalytic converter on the exhaust broke. TO save some buck I got just the flex pipe fix from a muffler shop. The guy did a good job but now I have been getting P0420/0430 errors and the engine Light comes on after i reset it. As for performance, I have not seen any change.
Can some advise or has experience how to fix this ?
16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
Possible Causes
Leakage in Intake and/or Exhaust System
Catalyst faulty
Oxygen Sensor(s) faulty
Oxygen Sensor(s) Control faulty
Possible Solutions
Check Intake and Exhaust System for Leaks
Check Catalyst
Check Oxygen Sensor(s)
Check Oxygen Sensor(s) Control
Perform Oxygen Sensor(s) Aging Check
Q7 Catalytic Converter, Checking.pdf
Possible Causes
Catalyst faulty
Possible Solutions
Check Catalyst
Hi Smith Its strange to get code for both the BANK (1 & 2) at the same time. Thanks for the input though, I bought a VAG COM cable online and am waiting for its delivery. Once I get it I will check with the Ross tech software as well.
@cuatrokoop, I agree with you but too much of a coincidence that both the flex leaking.
Does it matter if the flex pipe size varies from the original one installed.
Q7 P0420.pdf
part two is on my 1st link.
Also Smith I forgot to mention, I have a leak as we ll but it is at the joint in the middle where the end muffler is. The clamp joint is leaking. I dont think this can affect but good to have your input.
Also thanks for the input and the PDF. I am also thinking of getting the ECU flashed and then see what happens.
Hi Smith after reading your comment I got hte leak fixed and i was surprised that it did fix the errors. I reset the code after the fix and My I/M Status became yes after just 30-35 km of drive. But the next day I turned my car on and let it idle for like 5 -10 min and I again had both the codes in Pending. SO i just drove it for the whole day and again checked at night and the codes were gone. Today again I checked on cold start and I again have P0430 in pending. I will check the manifold to see if there are any leaks there. Also At certain RPM I have a bit of a different sound from the Exhaust so it looks as if I still have some leak.
