Q7 no start, no communication
#21
OK
this goes with the last three post for checking the ECM. TSB
Q7 Computer:Controls - PART OF ECM CHECK.pdf
#26
Pulled out the j271 relay and replaced it, no difference. Tested for power at relay and got 12V. Wondering now how to start looking at the various modules. A VW tech indicated to me that the only way to test these modules is to replace them with a known working unit. Is that the case? Will the car run if the faulty module has been replaced without it being coded to the car? Thanks
#27
Thanks
Thanks
If I have a faulty module, specifically either of the onboard power supplies or the gateway, if they are replaced (individually) will I know if this is the problem without having the ability to code them? Thanks!
#28
here is the scan, anybody have any insight here?
Friday,20,March,2015,10:06:24:45699
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0
Data version: 20150311
Ross-Tech: Home
Mileage: 179190km-111343mi Repair Order: 1
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
55 56 61 62 65 6D 6F 72 77
Mileage: 179190km-111343miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine
Cannot be reached
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FH HW: 09D 927 750 FH
Component: AL 750 6A 0959
Revision: 00H52000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 79F9AE75306BD1E9291-802C
2 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 5
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2006.05.10
Time: 12:00:02
008 - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2006.05.10
Time: 12:00:02
Address 03: ABS Brakes Labels: 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0017457
VCID: 285FBB319B41986106F-807D
3 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 09:37:17
Freeze Frame:
Count: 0
Count: 10497
Count: 128
Count: 34816
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 179197 km
Time Indication: 0
Date: 2006.05.10
Time: 12:02:09
Freeze Frame:
Count: 128
Count: 8961
Count: 297
Count: 44032
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 08:59:20
Freeze Frame:
Count: 128
Count: 8449
Count: 8194
Count: 39424
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100564407
Coding: 0000131
Shop #: WSC 08354 444 84041
VCID: 63C5EC1DA2E73B3913D-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
4 Faults Found:
00230 - Transmission Park Selector Switch (F305)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 6
Reset counter: 72
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:42:59
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 09:36:17
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:51
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:49:06
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 732 Q HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 308J.067508945
Coding: 0002003
VCID: 377D684D46FF07999F5-8062
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000001493398
Subsystem 3 - Serial number: 0127.01.100000000100010334ÿ
Subsystem 4 - Serial number: 010334ÿ
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:09
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---011 Serial number: 00000000078818
Coding: 0524328
VCID: 61C9E615B8FB2929011-8034
4 Faults Found:
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 32
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:44:11
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 8
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.02.28
Time: 13:23:31
Freeze Frame:
Voltage: 9.70 V
01317 - Control Module in Instrument Cluster (J285)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:49:33
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:53
Freeze Frame:
Voltage: 8.20 V
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0114123
VCID: 306F5351A391D0A1DEF-8065
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 72
Mileage: 179196 km
Time Indication: 0
Date: 2015.03.02
Time: 09:38:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 72
Mileage: 179196 km
Time Indication: 0
Date: 2015.03.02
Time: 10:49:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 111 A HW: 4L0 035 111
Component: CD-Changer H41 0100
Revision: 00000000 Serial number: AUZ5ZBF3050425
Shop #: WSC 00000 000 00000
VCID: 1E339DE9C90556D17C3-804B
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 11:53:30
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 29
Mileage: 160923 km
Time Indication: 0
Date: 2014.02.26
Time: 14:23:29
Freeze Frame:
Text: 00000000
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:51:27
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7J0559386
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:13
Freeze Frame:
Voltage: 8.40 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:49:13
Freeze Frame:
Voltage: 8.40 V
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD040WAA
Coding: 0014131
VCID: 2B55443D8AB7B379EBD-807E
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME1774431BD
Subsystem 3 - Serial number: 6342QSME17737721B
Subsystem 4 - Serial number: 6352QSME15064D6BN
Subsystem 5 - Serial number: 6362QSME176C0B3DV
Subsystem 6 - Serial number: 63734SME15062903R
Subsystem 7 - Serial number: 63834SME15063031L
1 Fault Found:
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90026062820104
Coding: 0012242
VCID: 275DB80D965F97190F5-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H07 0090
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 22
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:51:24
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.03
Time: 11:08:45
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H17 0120
Revision: 00600000 Serial number: 5HH31CLA6
Coding: 2641263
Shop #: WSC 01110 444 999999
VCID: 2345AC1DE2677B3953D-8076
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 150
Reset counter: 32
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:42:13
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:49:34
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06A140005
Coding: E5D7BE77303A02
Shop #: WSC 01127 444 123984
VCID: 6CD787214F397441A27-8039
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 118
Reset counter: 32
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:41:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:51:17
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082946
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 72
Mileage: 179196 km
Time Indication: 0
Date: 2015.03.02
Time: 10:51:14
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 D
Component: MNS US H48 0960
Revision: 00000000 Serial number: 313JP067508271
VCID: 2E534D29B9A5C651CC3-807B
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.03
Time: 12:37:28
Freeze Frame:
Hex Value: 0x54F6
Hex Value: 0xFD2D
Hex Value: 0x004C
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:51:15
Freeze Frame:
Hex Value: 0x54F5
Hex Value: 0xDB3B
Hex Value: 0x0041
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00000000 Serial number: @X
Coding: 0035531
VCID: 2F6D502DBEAFCF59C75-807A
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:23
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01021092710000
Coding: 7632925
VCID: 31695655A89BD9A9D11-8064
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 32
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:41:42
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H02 0150
Revision: PROD_01 Serial number: 00000000021115
Coding: 0000016
No fault code found.
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000047047
Coding: 0012001
VCID: 5EB3DDE9898516D13C3-800B
3 Faults Found:
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 72
Mileage: 179196 km
Time Indication: 0
Date: 2015.03.03
Time: 11:08:00
Freeze Frame:
Voltage: 6.000 V
Temperature: 3.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 164
Reset counter: 32
Mileage: 179184 km
Time Indication: 0
Date: 2015.02.18
Time: 06:41:00
Freeze Frame:
Voltage: 11.800 V
Temperature: -4.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 72
Mileage: 179196 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:00
Freeze Frame:
Voltage: 8.000 V
Temperature: 13.0°C
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00000000 Serial number: f
Coding: 0035531
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:35
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000021
VCID: 2959BE35804BA169191-807C
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Modul rechtsH06 0002
3 Faults Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 221
Reset counter: 32
Mileage: 179192 km
Time Indication: 0
Date: 2015.02.18
Time: 06:41:46
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 179192 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:51
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 40
Mileage: 8 km
Time Indication: 0
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388J.067560714
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:14
Freeze Frame:
Fault Status: 01100010
Fault Priority: 7
Fault Frequency: 245
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.03
Time: 11:06:52
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000049714
Shop #: WSC 08215 444 54285
VCID: 64C7EF01A7E93C01EA7-8031
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 310815F0SD
Coding: 344630393135313035442056413033313038313546305344
2 Faults Found:
03041 - Energy Management Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 136
Reset counter: 255
Mileage: 179079 km
Time Indication: 0
Date: 2015.02.16
Time: 10:31:15
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 127
Reset counter: 32
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:41:57
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0035338
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:54
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700032769
Coding: 0062424
VCID: 224BA919FD7D723158B-8077
2 Faults Found:
002 - Lower Limit Exceeded - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.03
Time: 11:08:45
Freeze Frame:
(no units): 255.0
Voltage: 6.00 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 179197 km
Time Indication: 0
Date: 2006.05.10
Time: 12:03:47
Freeze Frame:
(no units): 0.0
Voltage: 11.60 V
(no units): 27.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 1 - Part No: 4L0 910 946
Subsystem 2 - Serial number: E5030100B
Subsystem 3 - Serial number: RD18.10.06--H21001001C0022ÿ
Subsystem 4 - Serial number: 1C0022ÿ
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 40
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:21
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002064552-----
Coding: 0003595
VCID: 2643B50991558E11343-8073
Subsystem 1 - Part No: 4L0 910 591
Component: J_245_EE15_SKB09H10 0180
Subsystem 2 - Part No: 4L0 910 591
Component: J_394_EE15_SKB09H10 0180
Subsystem 3 - Part No: 4L0 910 591
Component: J_392_EE15_SKB09H10 0180
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 40
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:03
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0035338
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H16 1130
Revision: 00000000 Serial number: 00000007550812
Coding: 0010900
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:53
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 72
Time Indication: 15
End-------------------------(Elapsed Time: 03:28)--------------------------
Ross-Tech: Home
Chassis Type: 4L0
Address 01: Engine
Cannot be reached
Coding: 0000504
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2006.05.10
Time: 12:00:02
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Date: 2006.05.10
Time: 12:00:02
Revision: 00H22001
Coding: 0017457
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 09:37:17
Freeze Frame:
Count: 0
Count: 10497
Count: 128
Count: 34816
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 179197 km
Time Indication: 0
Date: 2006.05.10
Time: 12:02:09
Freeze Frame:
Count: 128
Count: 8961
Count: 297
Count: 44032
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 08:59:20
Freeze Frame:
Count: 128
Count: 8449
Count: 8194
Count: 39424
Coding: 0000131
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 72
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:42:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 09:36:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:51
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:49:06
Coding: 0002003
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:09
Coding: 0524328
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 32
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:44:11
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.02.28
Time: 13:23:31
Freeze Frame:
Voltage: 9.70 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:49:33
Freeze Frame:
ON
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:53
Freeze Frame:
Voltage: 8.20 V
Coding: 0114123
Coding: 00064792
Shop #: WSC 31414
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 72
Mileage: 179196 km
Time Indication: 0
Date: 2015.03.02
Time: 09:38:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 72
Mileage: 179196 km
Time Indication: 0
Date: 2015.03.02
Time: 10:49:00
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 11:53:30
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 29
Mileage: 160923 km
Time Indication: 0
Date: 2014.02.26
Time: 14:23:29
Freeze Frame:
Text: 00000000
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:51:27
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:13
Freeze Frame:
Voltage: 8.40 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:49:13
Freeze Frame:
Voltage: 8.40 V
Coding: 0014131
1 Fault Found:
Coding: 0012242
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 22
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:51:24
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.03
Time: 11:08:45
Coding: 2641263
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 32
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:42:13
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:49:34
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 32
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:41:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:51:17
Coding: 0082946
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 72
Mileage: 179196 km
Time Indication: 0
Date: 2015.03.02
Time: 10:51:14
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.03
Time: 12:37:28
Freeze Frame:
Hex Value: 0x54F6
Hex Value: 0xFD2D
Hex Value: 0x004C
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:51:15
Freeze Frame:
Hex Value: 0x54F5
Hex Value: 0xDB3B
Hex Value: 0x0041
Coding: 0035531
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:23
Coding: 7632925
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 32
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:41:42
Coding: 0000016
Coding: 0012001
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 72
Mileage: 179196 km
Time Indication: 0
Date: 2015.03.03
Time: 11:08:00
Freeze Frame:
Voltage: 6.000 V
Temperature: 3.0°C
Freeze Frame:
Fault Priority: 3
Reset counter: 32
Mileage: 179184 km
Time Indication: 0
Date: 2015.02.18
Time: 06:41:00
Freeze Frame:
Voltage: 11.800 V
Temperature: -4.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 11
Reset counter: 72
Mileage: 179196 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:00
Freeze Frame:
Voltage: 8.000 V
Temperature: 13.0°C
Coding: 0035531
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:35
Coding: 0000021
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 32
Mileage: 179192 km
Time Indication: 0
Date: 2015.02.18
Time: 06:41:46
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Mileage: 179192 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:51
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 40
Mileage: 8 km
Time Indication: 0
Coding: 0000002
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:14
Freeze Frame:
Fault Priority: 7
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.03
Time: 11:06:52
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Reset counter: 255
Mileage: 179079 km
Time Indication: 0
Date: 2015.02.16
Time: 10:31:15
Freeze Frame:
Fault Priority: 5
Reset counter: 32
Mileage: 179187 km
Time Indication: 0
Date: 2015.02.18
Time: 06:41:57
Coding: 0035338
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:54
Coding: 0062424
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 40
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.03
Time: 11:08:45
Freeze Frame:
(no units): 255.0
Voltage: 6.00 V
(no units): 42.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Mileage: 179197 km
Time Indication: 0
Date: 2006.05.10
Time: 12:03:47
Freeze Frame:
(no units): 0.0
Voltage: 11.60 V
(no units): 27.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 10
Reset counter: 40
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:21
Coding: 0003595
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 40
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:03
Coding: 0035338
Coding: 0010900
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 72
Mileage: 179197 km
Time Indication: 0
Date: 2015.03.02
Time: 10:50:53
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 72
Time Indication: 15
#29
Everything seems to point at the ECM, remove your wipers and plastic dip tray. Then look at your ECM on the passenger side, look for water or corroded pins.
#30
Thanks, will do. I am also going to check for power and continuity from the J271 main power supply relay socket to the appropriate terminal on the ecm harness to make sure there isnt a problem in between. If there is no problem I can assume its the ECM? such a bummer. Do these fail commonly?
