Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
q7 s line paddle shifter steering wheel conversion
Old 10-22-2014, 05:18 AM
  #11
arp2nr's Avatar
Thanks, when you reconnected the battery did you have to vag com it to clear any codes
Old 10-22-2014, 05:42 AM
  #12
Bklyn_Quattro's Avatar
Originally Posted by arp2nr
Hello everyone, I need some help, I just got a steering wheel for my Q7 and I have a question on what procedure you all use when removing the airbag and the battery:
which of these 3 procedures did you use when removing the air bag:
1. disconnect the battery then proceed to remove the airbag.
2. place trickle charger on the battery terminals under the hood then disconnect the battery and proceed to remove the airbag.
3. leave the battery connected with the ignition off and then remove the air bag.
any and all help is appreciated thanks
We disconnected the battery, then removed the old steering wheel and installed the flat bottom with airbag already in place, then Vag-com to clear codes(i cant remember specific codes or how many)
Old 10-23-2014, 10:06 AM
  #13
jago1's Avatar
for me pretty sure there were codes to clear, i cant recall exactly either , as I changed out other components too. code refresh also possibly requiring brief travel in the car also. sry for the spotty response . def need a vcds.
Old 06-22-2020, 02:51 PM
  #14
JAHWORKS's Avatar
Default 2011 q7 steering wheel harness
I need help I have a flat bottom wheel and airbag fits rite in but harness not plugging in
IntheQ5
Q5/SQ5 MKI (8R) Discussion
37
08-28-2023 11:37 PM
N'Syncro
33
02-16-2020 03:12 PM
mrprism133
09-07-2015 07:22 PM
Curtisjh
09-04-2015 04:06 AM
stormchaser1967
09-02-2015 08:48 AM
Quick Reply: q7 s line paddle shifter steering wheel conversion
