Q7 MK 1 Discussion Discussion forum for the Audi Q7 SUV built from 2005 to 2015
Q7 starting Problems
Old 04-12-2015, 12:18 PM
Wajidali's Avatar
Default Q7 starting Problems
Hi, my name is Ali, i'm new(ish) to the forum but have been lurking around for a while. I have a problem with my Q7 and was wondering if anyone could help. I have 2006 Q7 S line 3.0 tdi, it was upgraded to a 2012 spec inside out by the previous owner. For a while now, 6-8 months, i've been having problems with the car starting. The car can go day's with no problems and then it won't start, and then i have to jump start it, but if i drive it around for a while and then turn it off then try to start it again, it won't start again or it will take a few attempts for it to start. I've changed the battery, changed the alternator, the starting motor is fine. I even took it to the Dealers and they said it's the battery but still i get the same problem even though I've changed the battery. Can anyone help
Old 04-13-2015, 04:17 AM
smith2010Q7's Avatar
When you change everything did you clear all the faults on VAG and also uploded the new battery into the ECM computer with Vag?
Old 04-13-2015, 04:28 AM
Edd W's Avatar
When you say it will not start, is this because the engine will not start but the start etc... all seems to be working fine but no matter how long you try for, the engine will not start or is it that it gives symptoms of a flat or low level of battery charge?
Old 04-13-2015, 04:40 PM
Wajidali's Avatar
Hi, yes the the new battery was coded when it was put in
Old 04-13-2015, 04:42 PM
Wajidali's Avatar
Hi, when i turn the key the engine struggles to start, and then if i try it a few times the same thing will happen and then i get the message sayin Battery Low come up
Old 04-14-2015, 03:55 AM
Edd W's Avatar
Does your car have keyless entry and if so, do all four door handles work properly - does it open instantly from every door or do you have to pull the handle a couple of times first?
Old 04-14-2015, 04:34 AM
Wajidali's Avatar
No mate it hasn't got keyless entry
Old 04-14-2015, 05:18 AM
Edd W's Avatar
Is it the same when the engine is hot or completely cold?
Old 04-14-2015, 08:57 AM
Wajidali's Avatar
Yes, it does it when it's hot or cold
Old 04-14-2015, 12:51 PM
B490MTL's Avatar
Possible the battery is bad, you should still have a remainder of warranty on it so have it tested to see if it's the culprit.
Quick Reply: Q7 starting Problems
