Q7 Upgraded Front & Rear Sway/Stabiliser Bars
#11
http://www.clubtouareg.com/forums/f6...areg-9790.html
#12
AudiWorld Expert
i believe you have to do change in pairs changing the rear alone did not yield noticeable results. (again this is with adaptive suspension people with standard steel suspension may other results.)
#14
#15
Update: I turned the S and Q7 for some good coin and picked up a couple Tregs to mess with being comfortable with the cross-platform. Also, want to see what R32 motor tricks I could pull off. Anyway, the Cayenne S springs are gold. They will fit on the Treg or Q7. The dampers may have a different settings, but by the seat of the pants they match. The Treg springs are a smaller gauge wire and VW compensates with more coils. I have been using them on a V6 Touareg with 50K miles on the original dampers for 5K and it transformed the vehicle. There was no marked lowering below 1/2 an inch. Put on just the S rear bar and this car is handling just how I want for its intended road purposes. Q was awesome, but I made $22K from the sale ($15K from the Cayenne sale) and am surprisingly happy driving the almighty parent moniker. No 1%er hate/rage on the road in the Treg. I believe FI is in the future now. Brakes, Suspension, and Leistung 2ndary testpipe in place. Always fond of sleepers that spank over-confidence. Take care all. Won't be back for awhile.
#18
AudiWorld Expert
I currently have 7P0511025G installed. I would like to keep my current ride height because it dialed in perfectly for dynamic and auto mode without sacrificing ride quality but I would like to reduce a slight bit of body-roll.
I think I am going to go with Rear Sway Bar, Cayenne TT: 955-333-701-30 Rear Sway Bar, Cayenne TT: 955-333-701-30 25.6mm diameter (yellow) Rear Bushings: 955-333-792-30 (x4), New nuts VW Part# N10402902 (x4).
Has anyone on here done this yet on the newer Q7 with s-line and air suspension? I have not found any aftermarket options from h&r or similar.
#19
Bump to see if anyone with a Q7 has ended up, upgrading their sway bars.
I have an 04 Touareg with air suspension that I upgraded with the Yellow TT Cayenne swaybars, it was a night and day difference.
My 14 Q7 S-Line w/ air, drives like a bus around corners; I think its time to upgrade this baby. I have part # 7P0-511-025-G for my rear bar, the front is covered by the splash-shield, but I'm assuming its the corresponding green bar to the rear.
Parts that I ordered for my Touareg are these, of which fit this also:
955-343-701-50 Porsche Cayenne FRONT Yellow w/ air sus 37mm
955-343-792-50 (x2) - Front Bushings
955-333-701-30 Porsche Cayenne REAR Yellow w/ air sus 25.6mm
955-333-792-30 (x2) Rear Bushings
N10402902 (x4) Nuts for bar ends
#20
Alright, just completed the order for the Cayenne Yellow sway bars... I'll repost once I get them installed for a review.
