ross tech
ross tech
hey guys i just got 2015 Q7 AND I WANT TO RECODE IT 2 THING I WANT TO DO (1) i want the code so all window can come down when i press and hold the unlock button and the remote...(2) when i start up the car i want the needle to go back and forth like the rs6 in the dash ??? i know it can be done because i had it done to me 2009 Q7 SOMEONE did it for me
If that's all you want to do, you don't need a Ross-Tech VCDS cable. Get the Carista app and OBDII bluetooth module.
Carista OBD2 - Vehicle Diagnostics and Customization | Your car, your way
Review
Can you review it for us?
I don't own it yet but others have and it appears pretty easy to use and straightforward. Peruse the linked thread.
https://www.audiworld.com/forums/q5-...e-app-2874000/
Enabling Gauge Test/Needle Sweep
This will sweep the gauge needles through their full range automatically when you start the engine.
[17 - Instruments] [Coding - 07] -> [Long Coding Helper] -> Byte 1 Bit -> 0 Change 0 to 1 Or Check the box for "Gauge Test/Needle Sweep active"
Operating Windows and Sunroof with Remote
This will allow you to hold the Lock and Unlock buttons on your remote to open and close the windows and sunroof
[46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] -> Or Check the box for "Comfort Operation: Remote Control active"
Then go to new MMI car system menu and check comfort windows and sunroof.
Thanks bro.... where do i find a list of things that i can do to my Q7 with the ross tech or maybe you can help me with some tip and trick with the coded.
my email is taylor4472@gmail.com
These Vag=Com mods should work:
